Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water Leak I have a Whirlpool Model # ET1CHMXKQ03 Refrigerator with a freezer on top. Water drips from the rear underside of the freezer in the refrigerator compartment onto the back part of the top shelf. It amounts to about 1/2 cup of water in 24 hours.
  • 12 more comments
  • SethII Feb 20, 2008
    There is no funnel tube on the back wall of the refrigerator.
  • Grandview Feb 24, 2008
    We own two vacation rental condos in Missouri. Same frig's with same problems. Ice clogs the drain tubes and then the water drains into the frig filling the bottom and then making a mess of the shelves. The solution eludes me. The settings are on normal but there is very little food in each frig ( most people don't fill them up). But no matter, this should NOT happen. This is a BAD design and needs a recall. The next fix for us will be to run the drain tube externally. I hear there was some kind of kit that WP had. Any ideas? Otherwise, I'm cutting into the back of the cabinet.
  • robert pai Mar 03, 2008
    I have the same whirlpool ref, same problem. It was two years new.
    please let me know how to fix it .
  • Belmonttf Mar 23, 2008
    Freezer drain freezes and therefore the melted water overflows to the top shelf of the refrigerator.
    I have to defrost the freezer for the ice to melt and therefore melt the ice in the freezer drain.
  • Anonymous Mar 26, 2008
    I have a whirlpool mod#ET21MMXJW00 top freezer. I am now having water drip don inside of the refrigerator to fill up below the fruit and veg bins were air flow is to occur. I am also having water freeze under the try in the freezer. The setting for both are at the required settings. What can be done to fix this problem?
    Thanks
    Tom
  • jack csh Aug 10, 2008
    same as above tech came to the house and has done what you said and still have the same problem any help he says heater core needs to be raplaced
  • lspopeil Aug 13, 2008
    I have the same problem- I don't use ice-maker and thought that that was perhaps the problem. Will try the cleaning of the funnel tube. Thanks
  • Thompsh Sep 07, 2008
    Water drips from the top Freezer
  • Anonymous Feb 11, 2009
    water drips down the back of the inside of the refrigerator down to the bottom under the crisper drawers and collects overtime. I have to **** the water out otherwise it overflows onto the kitchen floor. My refrigerator works fine other than that.
  • giterdone26 Feb 13, 2009
    theres no tube there to pull out its just a plug it leaks water in to inside bottom
  • Anonymous Mar 05, 2009
    Water collects in the bottom of the fridge. There is no ice maker, so this is not a cause.
    Does this require repair or replacement?
  • Anonymous Mar 18, 2014
    whirlpool ET1CHMXKB02 top freezer refrigerator wiring diagram
  • Anonymous Mar 22, 2014
    a small amount of water drips into the refrigerator (mod 106) from the back airway from the top freezer compartment.
  • Anonymous Mar 24, 2014
    water leaking from bottom
I have a whirlpool et18gkxgw0 and it leaks water alot into the bottom inside by the crisper drawers i do not have a tube on the back of it there is a spot for one but its plug with a plug not dirt or anything someone put it there is it not suppose to be there please help
Posted on Feb 13, 2009
  • 770 Answers
Pull the funnel tube out of the back wall and clean the drain that goes out the back wall of the refrig section
Posted on Feb 18, 2008
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
My drip pan under the frig over flows with water then on to my floor. both fans work. Air flow from freezer to frig and back seams good. Tube going to drip pan is clean. Seals looks good and clean. MOD...
I had a similar problem with my Whirlpool model 6ED25DQFW side by side refrigerator/freezer with ice maker/water dispenser. Water was slowly pooling under the refrigerator under the freezer section. The defrost drain pipe was not blocked, the condenser fan was running, the drip pan was not leaking.
The source of the leak was found to be the icemaker solenoid block plastic body which had a pinhole leak.
To fix requires either plastic welding, or replacement of the solenoid block plastic body.
To access the solenoid block firstly requires removal of the cardboard cover, located at the lower rear of the refrigerator.
Aug 16, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Where is the defrost drain in a whirlpool refrigerator model number ET1FHMXMQ00
It's part 7 in this diagram. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5149338&diagram_id=929467#d929467
It's behind the rear cover inside the freezer. From there the water drains to the drip pan underneath the fridge where it's evaporated by the condenser fan.
Jan 30, 2010 | Whirlpool ET1FHTXM Top Freezer...
How can i check to see if the defrost is working in my whirlpool refrigerator model number ET1CHMXKQ03. Initially water started leaking into the fridge from the freezer, i looked and saw everything iced...
you will need to access the heater in the rear area of the freezer compartment and disconnect the heater element and take a continuity test of the element,if this checks good,then in the same area is your defrost timer,unplug the heater from it and hook up a voltmeter and energize the defrost timer manually and see if you have a voltage there
Jan 16, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool ultraease refrigerator (ED7FHG) making water sounds, and drips water onto steel pan in bottom rear of freezer side. Purchased new. This is an obvious change. Problem?
You have a water leak somewhere (I'm assuming this water sound is constant). If not write me back for other possible solutions.
The only place water comes into the freezer is for an ice maker or a door water dispenser. Check around the ice maker for a leak. If there is a water dispenser in the door then check the piping to it also.
There is a drain in the bottom of the freezer compartment which is there so when the frost is melted by the defrost heaters, it has somewhere to go. This drain drains into the "drip pan" (or condensate pan) in the bottom of the unit. Here the water will sit until it is evaporated into the air.
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Whirlpool 21.7 cu. ft. Top Freezer...
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Sep 06, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
848 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
