Question about Price Pfister Plumbing
F-WKP-650 SPOUT WILL NOT STAY WHERE YOU PUT IT. IT SWINGS TO THE SIDE AND IF YOU WANT TO USE IT IN THE OTHER BOWL YOU NEED TO HANG ON TO IT
I had this same issues with a peerless faucet. The spout would not stay in place. I found that there is plastic sleeve/washer that does not grip the spout properly. What I did was remove the stem. On my faucet there is a tiny whole behind the stem, you push his in and pull off the stem. You'll see a plastic sleeve. I basically got some putty and put a thin layer inside it so it would grip the metal better. So far it is working not sure how long it will last but works for now.
Posted on Feb 07, 2010
  • 1202ym Nov 19, 2010
    I tried to push in the the hole but nothing happened. What did you use to push it with and how hard ?
Where can I buy a mixing bowl with a funnel spout?
bed bath and beyond has a lovely mixing bowl with funnel spout. Even made from 100% recycled plastic! http://www.bedbathandbeyond.com/1/1/45883-preserve-bpa-free-mixing-bowls-set-of-3.html
Aug 05, 2013 | Home
Will not start
hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.
Feb 18, 2012 | Cub Cadet Garden
How dose the carboretor work
Feb 10, 2012 | Garden
Small engine won't start
hello sir, mower will not start or run, does it have good spark,good compression,or only runs on full choke,engine surges up and down, are you getting fuel to the engine if not try this, your carb. is clogged up here is what you can do for a simple repair and other things if you want to, you will need a new air filter,spark plug, oil, if you want to a new blade also ,sears has a mini tune up kit that you can buy. now for the carb, empty fuel tank, place mower on side to where carb is facing up place a rag under carb to catch excess fuel,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bowl nut in, now while you have mower on side drain the oil remove filler cap to drain,put pan under spout,mower holds 21 o/z of 30 wt oil,you can remove blade to get sharpened or put new one on,to remove blade put a pair of vice grips on the body where the blade can stop and not turn it is usually a 9/16 or 1/2 socket, put blade on add oil,add new and fresh gas,you should be good to go,hope this helps,what i am telling you here is what i would do if it was here in the shop,any comments welcome,thank you.~~
Feb 09, 2012 | Garden
Cant get 5.5 hp Briggs and stratton to start after cleaning out fuel lines tank and carburator changed plug it ran for a sec then died again what now
Jan 22, 2012 | Mtd Garden
What is the purpose of the small hole at the back of the toilet bowl?
f you are asking about the small hole on the back out side of the bowl it is there to hang the toilet when they put on the porcelain coats.
Feb 21, 2011 | American Standard Cadet 3 Right Height...
My husband just got a suzuki savage and had to take carburator apart there is 2 hoses that he cant find where they go please help!!
If they are small tubes , the one on the side is probably just a float bowl vent and goes to the front of the rear wheel. The one on the bottom of the carburetor bowl is the drain hose for the bowl and goes to the front of the rear wheel. The vent and drain line just hang in front of the rear wheel and do not connect to anything.
It is possible that one of the lines is a vacuum line and does actually have to plug into a vacuum fuel petcock. If this is the case the fuel will not flow to the carburetor unless the line is hooked up. Hope this helps.
Oct 25, 2010 | 1997 Suzuki LS 650 Savage
My mower wont stay on for more than 2 seconds after starting. Help!!
Remove the float bowl from the carburetor and clean it as well as the main jet up in the center of where the bowl nut screws in using an areosol carburetor cleaner
Sep 19, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
We have pressure on the cold water side but not on the hot. The faucet in the bathroom sink has hot water pressure.
make sure your water valve is working properly undo line and open valve if its working than take apart faucet and check for debri
Jul 17, 2009 | Moen 7310 Legend Single-Handle Kitchen...
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
May 03, 2009 | KitchenAid K5AWH Stand Mixer
Plumbing Logo
504 people viewed this question
Top Price Pfister Plumbing Experts
john h
Mike
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
