Question about Samsung SCX-4216F All-In-One Laser Printer
Toner light stays on after replacing toner cartridge
I have used several different cartridges and still the toner light stays on after replacing toner cartridge.
  • Anonymous Feb 18, 2008
    I have the same problem as bellow
Clean the scanner unit or ross assembly
Posted on May 19, 2008
Your a champ, works a charm
Posted on Mar 05, 2008
Check the fuse on the front of the cartridge. it is designed to blow on cartridge installation. Replace with 50 milliamp, should solve your problems
Posted on Feb 26, 2008
Nestindia@yahoo.com
Posted on Feb 18, 2008
Hi, First check you have installed the toner properly. Reinstalled the toner cartridge after making the cartridge clean.
If the the printer cannot recognize the toner It may happens. Check it properly.You may have to replace the cartridge.
Oct 17, 2011 | Office Equipment & Supplies
Toner on the side of paper when copying
If you are using refilled toner cartridges then your toner cartridge may be leaking or the waste toner tank on the toner cartridge may be leaking. The other cause and more likely is the drum cartridge is leaking toner. I would recommend removing both cartridges. Then hold each 1 at a time over several sheets of clean white paper. Tap on the cartridges and see if any toner falls out of them. These cartridges are normally sealed and should not leak much if any toner. If toner falls out of either cartridge you will need to replace that cartridge.
Good Luck and Thank You for using Fixya.
Mar 27, 2010 | Sharp AL 1631 Copier
I have a brother 2140 printer, it ran out of toner and i refilled toner starter cartridge , and error message comes back to clean the corona , i replaced ther cartridge with a new tn-360 cartridge, but...
When it says to clean the corona, on the drum there is a purple tab that moves from one side to the other. run it back and forth a couple times that should solve the problem.
I dont recommend refilling the cartridges, we have had several issues in repairing those printers with refill. if you must use refills, i would recommend getting 2nd or 3rd party manufacturers.
if you need help, you can contact us.
thanks adi
Dec 31, 2009 | Brother HL-2040 Laser Printer
Toner indicator light stays on even though it has been changed. There are no loose parts left in form the toner cartridge used before.
I just had the same problem. We have several of these in our office, but switching toner cartridges made no difference. Then I saw this site: http://www.oasis-imaging.com/images/pdf/cart_inst/TN580.pdf
I did steps 14-16, which takes 5-10 minutes. I put the toner back in the printer, turned it on, and it works perfectly now. Give that a try!
Apr 21, 2009 | Brother HL 5250DN Laser Printer
After replacing toner cartridge, error/toner lights stay on
Open the front of the printer then hold down the cancel button. When the lights flash close the front and it should Reset.
Apr 02, 2009 | Dell 1710 Laser Printer
Replaced toner cartridge and light stays on the printer will not
how do i set the toner reset lever on a brother hl 5250 printer
Mar 31, 2009 | Brother HL 5250DN Laser Printer
First and 4th yellow lights stay on
You should still be able to do a printer test page (press the arrow button).
Look at the printed page(s) for the Photoconductor AND the Toner.
They show as OK when new (or very low count), and 100% when fully used.
It IS ossible that the toner cartridge has a faulty (or if a remanufactured cartridge - un replaced) chip.
Some 'after market' chips are not compatible with E250, and it IS possible that your replacement cartridge is for an E350, or E450 (which have different chips, and some of the poorer remanufacturers , and some reselers that don't do these very often don't know).
It could even be a Dell 1720 chip on the cartridge.
I make around150 Dell 1720, 20 E450, 50 E350 cartridges a month and only around 5 E250s, so this gives you an idea of the relative numbers, in the market
Oct 25, 2008 | Lexmark E250dn Laser Printer
Ricoh cl3500 printing light
Check the transfer roller. Its a black spongy roller in from of the drum. Make sure it is getting good contact. Did you shake the toner cartridge before you installed it?
Sep 29, 2008 | Ricoh Aficio CL3500N Laser Printer
2200d hp laserjet
The green flashing light lets you know that the machine is recieving data. This is completely normal, however, the red (Attention) light can mean several things. There can be a door open, missing toner cartridge, out of paper, or paper jam. In this cause it is probably the toner cartridge. Typically on these machines there is an Orange or Green tab on the side of the toner cartridge that needs to be pulled to fully engage the cartridge. You may want to make sure this has been pulled and the cartridge has been properly seated.
Hope this helps...let me know if you need any further assistance
V
Sep 19, 2008 | HP LaserJet 2200D Printer
50 Copies Per Toner Cartridge?
sounds just like the 'idiot' lights for oil changes on your car..how about this..100 copies from replacement, does the light go on?
http://tinyurl.com/6qcpgy
Aug 18, 2008 | Brother HL-2040 Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
208 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
