Question about Whirlpool Washing Machines
Whirlpool Washer Leaking
I have a Whirlpool Washer # SM 8525147-A top loading. It has been leaking from the front. I have checked all hoses and it seems be alright. What could be the possible reasons?
1. Seal - maybe but how do I check?
2. Cracked drum - I don't think so but if this is it how do I check?
Opened the Washer and found there was a leak in the pump. Got an M-Seal and just put it on the leak. 45 mins later the machine was in action again.
It took time for me to figure out where the problem was, once you know exactly where it is you should be able to fix it.
Posted on Feb 01, 2010
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
Washer leaks during fill up
check the bottom of the inlet hose where it enters the machine. It is most like;y a split hose or a corroded valve.
Sep 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Light is blinking FH
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
FH?
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Aug 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machine
If this is a front loading machine, take the plug off the wall. Remove the screws of the panel behind take off the panel; check to see whether any hoses hav come loose, tighten, refit.
Sep 11, 2007 | Whirlpool LSN1000LW Top Load Washer
Awm 5145
Possible your hoses into the dispenser box hv a problem; plug off wall. Open the top of the machine to examine the hoses.....
Jun 24, 2007 | Whirlpool AWM5145/2 Front Load Washer
Washing Machines Logo
362 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
