Question about Samsung Refrigerators
Have a samsung rs2533 refrigerator, making noise when it cools
Have a samsung rs2533 refrigerator, it is making a weird noise, sounds like a fan in the motor...not sure what to do....the noise happens when the refrig. is cooling...
  • 958 Answers
SOURCE: 5 year old Maytag Wide by Side Refrigerator side not cooling
try to defrost it manually. the defrost heater cycle is malfunctioning.
Posted on Feb 13, 2008
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
Posted on Mar 18, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
Sebin
  • 712 Answers
SOURCE: Refrigerator making noise like ball bouncing
No. This is not a great deal. Your compressor is switching off at times which makes the sound, but it is a power saving technique adopted by the manufacturer. It is certainly not a problem.
Posted on Apr 23, 2010
heatman101
  • 43501 Answers
SOURCE: Top refrigerator part not cooling, bottom freezer and fan working
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
The fridge make weird noises some days. Cooling is good, freezer also works well. My concern is if those noises are prelude to a major damage.
This really depends on the type of noise. If you hear a gurgle type noise while running this is usually normal from the refrigerant pumping through the tubing. Fan type noise blowing air in the freezer section is also normal but if it sounds link the fan is rubbing or grinding you need to look into that noise. Also a similar fan down near the compressor area in the lower back section. A low hum from the compressor while running is normal. If you have and icemaker--water running noise about once per hour for around 10 seconds is all normal while the icemaker is filling. Dropping noise from the cubes falling into the bucket is also normal about once per hour. Hope this helps.
Jun 10, 2015 | Refrigerators
Why is my Samsung RF26XAERS refrigerator repetitively chiming, and how can I fix it?
NOISE? from the fridge inside? or from the outside compressor? In overstressed compressor or low freon level will make weird noises? a bad fan in freezer will? Even seen bad ice makers make weird noises? if the ice making is hindered by obstructions?
Aug 20, 2014 | Samsung RF26XAERS 26 Cu. ft. French Door...
Samsung model RS2530BWP side by side is not cooling fan in the back making load noise off and on
that is coming from your fan check for any ice build up if none then I would replace the fan. u can find the part at applianceparts,com
Apr 10, 2014 | Samsung RS2534 Side by Side Refrigerator
The fan is making a weird noise and when i open the door it stops but when it stops in makes a loud noise and the temp on the fridge wont stay down but the freezer is fine what is the problem
You have a twin cooling unit and the refrigerator fan is getting clogged up with ice possibly due to a defrost problem. You will need to remove the back wall panel of the refrigerator to access the evaporator fan motor and clean it out of the excess ice buildup. Check the defrost circuits and also the defrost drain to make sure it's clear.
Jul 20, 2011 | Samsung RS2630SH Side by Side Refrigerator
Freeze doesn't freeze and fan in fridge is now making noise
Usually when the fan in the freezer is making noise it is because there is ice built up and it is hitting the fan...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
heatman101
Sep 27, 2010 | Samsung RB1955VQ Bottom Freezer...
Why is cooling fan making weird noises
Depends on what the weird noise is...kind of a squeak? Fan bearing are going out....clicking or dragging sound? the fan blade is hitting something....
Feb 08, 2010 | Toshiba Satellite A45-S130 Notebook
Jenn-Air JCB2059ES refrigerator makes weird noise
Sounds like the plastics are just rubbing from vibration. redistribute the contents of the drawer and see what that does. Good Luck.
Nov 21, 2009 | Refrigerators
Loud noise from the freezer side
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Oct 12, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
212 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
