Question about Kenmore 43142 Front Load Washer
F- error sign
Have the kenmore2+ HE machine. keep geting an error that says F-. how do i fix this?
  • 15,935 Answers
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes:
* Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
* Check the MCU
* Check the Wire Harness
begin troubleshooting right at the motor. Why start there? Because the motor is one of the prime suspects and it's easy to check. Remove the back panel and unwind the belt from the drum pulley. Now turn the motor pulley (sans belt) by hand. If it doesn't turn smoothly and easily, you have a bad motor.
If the motor pulley turns smoothly and easily by hand, next step is to run the motor with the belt still removed from the motor pulley. If the motor seems to run fine that way, put the belt back on and run it again. If the motor won't run under load (with the belt on), then that's another sign that the motor is bad.
Suppose the motor turns easily and freely by hand but won't run either with or without the belt. This is a more subtle condition because we're probably dealing with a bad MCU or flakey wire harness somewhere between the motor and MCU, or between the MCU and the CCU.
One trick that often works at this point is to remove and reinsert all wire connections at the board and motor. This tends to clean the small amount of corrosion that will build up on the connections. After you do this put the machine into a service cycle (see the instructions in the tech sheet found inside the unit or you can ). Part of the service cycle is running the motor at certain set speeds which checks the tach.
If you've removed/reinserted the wire harnesses and still no joy, then usually the problem is the MCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
Can't sign too internet my wifi is ok i have the nb09 tablet
Hi Rodney,
it appears your device has an authentication error when establishing a connection to the WiFi source, first you need to *forget* the network via Tablet, then disable WIFI connection on this device and enable it again, when searching for the connection, make sure you type the security code correctly and choose connect option, check and confirm problem solved, if not, let me know please
Jan 29, 2014 | Computers & Internet
I keep geting a dns error code 80710102 on my ps3 what is this
Hi Sir
80710102 PS3 Cannot connect to the router with current IP information - Try rebooting your router
May 19, 2010 | Sony Playstation 3 (PS3) Console
Temperature is too low error comes up when i have warmed the room up it still keeps coming up and machine wont work
problem fixed the cause being a loose head ribbon cable caused by my braslet catching on the edge of head ribbon cable and pulling it out off top socket plate all fixed after phone call to neil riely from Riely Signs (the nicest guy in signs) thanks
Oct 14, 2009 | Office Equipment & Supplies
I keep geting error 80010002 from downloding
it does that when you are trying to download undownloadable games
Jul 06, 2009 | Sony PlayStation Portable (PSP) Console
I keep geting Service Error 1500 when trying to print
I don't see an error 1500, error 5100 though means the carriage can't move right and left or there is grease on the encoder strip behind the carriage.The grease you can clean with a Q-tip, and also make sure there is no paper scraps on the right or left side of the machine...
Jun 26, 2009 | Canon i860 InkJet Photo Printer
I keep geting an error message every time I go to a web page
Do you have an anti virus program on your computer? If so, it could have something to do with the setting on it.
Oct 31, 2008 | Computers & Internet
Kenmore 43142 Front Load Washer Logo
97 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
