Question about Roper 24 in. RUD0800EB Built-in Dishwasher
I'm assuming Roper dishwasher model RUD0800EB0 no longer sold. Is there another dishwasher same size?
When was Roper GAs Range model 1336 sold
What problem are you having?
Dec 04, 2012 | Kitchen Ranges
Part for a Roper Tractor. A long shot I know, but would anyone know a dealer that might ship a part to the UK? The part I require are the 3 deck wheels situated immediately in front of the cutter...
One would think there is a US vendor out there who has these parts and will ship internationally. A google search for Roper mower parts would turn that up. Roper may be a special case, but almost all US lawn tractors are made by MTD/AYP regardless of the actual name printed on the mower.
Those deck wheels, to my knowledge, only come in 2 generic sizes which are based on the size of the deck. Both Lowe's and DIY have big boxes of them for sale, at least here in the US, in the area of the store where mower blades and belts are sold. If they are a bit narrow, spacers come in handy and if a bit wide some material can be cut or ground off.
Good Luck
Sep 13, 2011 | Garden
How do I take the pump assembly off a roper dishwasher, model rud3000kb1? I need the first step and that's all.
onthejob5130.gifi hope this helps..please be minded,that dishwashers are not grounded ,please cut power if working around motor..good luck
Sep 08, 2011 | Roper Dishwashers
I saw a thread that said someone had a user manual for a DU4500B Magic Chef dishwasher. I have one in the house I moved into and I'm looking to replace it, but there is no manual and I do not have the...
Magic Chef was recently sold and the company that bought them no longer publishs online the Magic Chef manuals any longer. However all built in dishwashers are a standard size and any new one will fit in the opoening of a pre-existing one
I'll give you this link http://mcappliance.com/magicchef.aspx and you could try to download the manual but i am 100% sure that all built in d/w's are a standard size
Aug 21, 2011 | Dishwashers
We have just purchased a new washer and dryer and we are finding that in the rinse cyce is not filling it up like our older model washer is this normal? On our dryer we are finding that there is no longer...
Hello
if this is a high eff,water saving washer it is normal.The machine will sence the size of the load at put in enough water depending on size and where you have the load set.
Jun 19, 2011 | Roper Washing Machines
What are the exact cabinet dimensions of a Roper dishwasher, model #RUD3000? Thank you!
The manufacturer specified cabinet dimensions for this model are:
Total width: 23 7/8" / 606mm
Total height: 33 7/8" / 860mm
Total depth (front to back): 24" / 610mm
If you need any further specifications for this model, please reply within this solution.
Regards,
BElectric
Nov 18, 2010 | Roper 24 in. RUD3000 Built-in Dishwasher
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
Oct 25, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Dishwasher on no water
Is the water valve under the sink on? Any kinks in the hose? Check to see if the water valve solenoid coil is open (located under the cabinet front).
Oct 12, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Top rack keeps slipping off of tub rollers.
I was sold this model and had the same thing happen.. However when calling for service, my service rep would not come out, so I contacted Fridgidaire and provided the model and serial # of my unit and was told I was sold an unrepairable unit that had already been returned for service for the same thing and considered unrepairable and was no longer under warranty. When my supplier finally came out he put new longer rollers in my dishwasher, but when I mentioned what Fridgidaire had told me, he went back to his supplier and they got me a new one. Being installed today.. The new one is a PDA2855 model as I am told that the PLD2850 is no longer sold.
Mar 31, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Dishwashers Logo
170 people viewed this question
Top Roper Dishwashers Experts
Mike
paul
paul
Adzhall
Are you a Roper Dishwasher Expert? Answer questions, earn points and help others
