Question about Eureka Capture Upright Vacuum Vacuum
Eureka Capture Vacuum
The canister isn't filling with carpet waste material, instead the hose on the back is getting clogged with the debris. How do I shut on the airflow to the hose while I am using the vacuum upright in order to collect dirt in the canister?
  • wendellmckee Oct 24, 2008
    vacuum will not pick up, roller turns, but no suction.
  • 33 Answers
1 ) That unit cannot shut off the airflow to hose while unit is used in upright position. The hose is in constant use, whether you are using attachments, or vacuuming the floor.
2) It does sound like you have a clog somewhere in the unit. Most often it is the grey filter screen is full, (which is located just above the dust cup...instructions found on sticker on back side of dust cup) which causes everything to clog or back up. You should check this piece every time the dust cup is emptied.
3) To check for clog in main hose, remove the square clear hose adapter (with a phillips screwdriver) from the back of the unit and pull out the grey plastic attachment end of hose from the side of the unit by the duster, and unwrap the longest part of hose from vacuum and lay it on the floor. Get a quarter or a nickel and while holding the clear square adapter end of hose up , drop the coin into the hose, shake the hose to see if the coin will roll all the way out the other end of hose onto the floor. If it comes out, re-attach the hose adapter , making sure the little foot is in place, and with the dust cup locked in place, turn the unit on, test suction at end of the hose, it should be strong. But, if itdoesn't come out, there is a clog. The grey plastic hose retainer at the bottom of the unit is open where you can stretch it over the hose and free the hose from the unit.Take something like a mop handle or broom handle,(I've also found a long dryer lint brush to be helpful) insert into the hose to break the clog loose. Repeat the coin test. When the coin comes through, reattach the hose.Test for suction.
4) To test the lower portion of hose for a clog (from the duster unit to the brushroll area in base) with the attachment end of the main hose out of the hole, you should be able to look down the opening and see into the lower portion where the hose curves into the base. Drop your coin in the opening (not in the duster tube) it should, with gravity, roll out to the floor. However, it may stop at the brushroll, so tilt your unit forward, and side to side to see if it comes out. If that doesn't make it come out, there is a clog in that lower hose.
5) To clear the clog, recline the handle all the way down on its back( again like vacuuming under a bed) roll the unit on its "belly", you should see the lower hose straighten out more, Insert something blunt into it, broom handle, or a bent wire coat hanger (bend to protect hose from puncture) and you should be able to clear the clog. If it still wont clear the clog, remove the 4 screws from bottom of unit and take hood of unit off to see the opening of bottom end of lower hose, near the brushroll. Clean out clog from that end. Once cleared, stand unit upright, re-test with the coin until coin rolls out freely. Put all parts of unit back together.
6) Make sure the height adjustment pieces are still attached to bottom of unit. (the plastic piece with 2 wheels and a spring) Reset this component, by reclining the handle in normal operating position, lean down turn height knob on hood to the highest carpet setting, and flip it slowly over to the bare floor setting, do this back & forth 4 times... over & back is 1, etc...then determine your carpet height...( berber is like normal carpet ) set the knob (with handle still reclined) on the middle setting, then place unit back in upright position. Test the vacuum for approx. 1 minute. While testing the unit, look into the dust cup and see if the dirt is swirling. If it isn't, then check the dust cup filter,(under the dust cup) to make sure it is clean. If it is coated with dirt, etc...,remove the filter tray , pinch the foam filter and pull out of tray.Tap the filter over a trash can, or replace it if you have a replacement foam filter handy. Replace foam filter in the tray, replace filter & foam into unit, close the lid, replace the dust cup and lock in place. Re-test vacuum.
7) If all the above steps are followed, this should prevent future clogs in unit.
Posted on May 17, 2009
    President:
  • 1,673 Answers
Either the filters are clogged, the hose has a clog in it, or the dirt inlet down by the brush roll is clogged. Pull the hose off and see if you have suction at the end of the hose, that will tell you which way to look for a clog.
Posted on Mar 02, 2008
Why doesn't suction work on eureka
The hoses may be clear but debris could be clogging the point where it is discharged into the bag or container. There also could be a debris clog at the intake.
Sep 03, 2014 | Eureka Vacuums
Vacuum picks up some dirt and debris but not all, and spits some back out?
Some blockage at the pickup or in the hose if it uses one---dirt etc being kicked back out is a clear sign of this----if it has a tube check that first, and if a head with turning brush do not miss looking for a blockage there.
Dec 11, 2012 | Eureka True Clean Upright Vacuum (Yellow)...
Eureka pet expert vacuum lost suction
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
Jun 05, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
No suction
there is a clog somewhere :) take the canister off and check the opening and the hose. sometimes items get caught in the top of the canister.. this greatly reduces the whirlwind effect..
Mar 28, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
My Eureka capture bagless vacuum has just started making a loud siren like sound. It is deafening. what is the problem?
does it smell like burning rubber if not check beater brush it sounds like something may be jammed in it or near where it goes up past beater bar into the vacumn inlet if you do have a burning smell the motor shaft is spinning and thinning the belt and may also be making that sound as shaft spins on loose belt
Dec 26, 2009 | Eureka Capture Upright Vacuum Vacuum
Eureka bagless uno 12 amp ( green)
Buckaboo, you say the debris no longer collects in the cup? Does that mean you don't have suction as well?
The brushroll has it's own motor so the brushes spinning doesn't necessarily mean there's not a problem with the wiring, the switch, or the motor.
Assuming you haven't inadvertantly set the selector switch to floor when you wanted to use the hose or vice versa, try the following.
Start with the motor/impeller first. Take the dust canister off and turn the vacuum on. It doesn't matter if you turn on the brushroll or not as you're looking for suction.
With the vacuum on feel for exhaust out the front of the motor (by the secondary handle on the bottom. Also put your hand over the area where the dust canister sits. You should feel strong exhaust and suction respectively.
If not, then you should take it in to a technician as going any further requires disassembly.
If you feel there's enough suction, then it may be as simple as a clog. This vacuum has a particularly easy air path to check. There's a clear snap-on door on the bottom to check the brushroll and neck. Then from there it's a straight shot through the canister itself before dumping inside and going through the filter. If it's the hose, you can turn the end clockwise to remove it from the body of the vacuum and use a broomstick to clear any clogs.
If it's not a clog or filter then you may try cleaning the seals (one round at the bottom of the canister where the canister mates to the body and a rectangular one in back of that where the dust runs up and into the canister.
Good Luck!
Oct 03, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Clogged vacuum hose
I used a snake like they sell for unclogging pipes. I can use the snake on one end to break it up. I attach the other end to my industrial wet.dry vac and **** it clean. Sometimes I cannot imagine how it fills half a five gallon bucket of dog hair and stuff.
Jul 30, 2008 | Kenmore 22812 Bagged Canister Vacuum
My eureka 2961avz bagless vacuum has no suction
Usually clogs are in the dirt inlet by the brush roll, or in the hose. Take the hose off from the bottom and see if there is suction, if not, then the hose is clogged. If suction there, then it is lower. Also is the brush roll turning, if not, that could be your problem.
Jun 06, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Clogged Bissell
Something must be in the hose causing a clog, take the hose off and if suction is good where the hose hooks up, then there is something caught inside the hose.
Mar 23, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Eureka Capture Upright Vacuum Vacuum Logo
572 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
