Question about GE Refrigerators
Problem with GE refrigerator
GE refrigerator model # GSC23LSRCSs, serial # MH441608 is having problems. The ice maker and water dispenser suddenly stopped working. Also, the temperature control readings for both the freezer and refrigerator compartments are not lit. Please help!
  • 10 Answers
SOURCE: GE profile refrigerator model # TBX25PR
See if ice is jammed up in the tunnel the ice is pushed through.
Will the motor turn the auger with all the ice removed.
Posted on Jan 25, 2008
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
SOURCE: Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Posted on Sep 16, 2008
  • 219 Answers
SOURCE: Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Posted on Mar 19, 2009
I have a GE refrigerator model gfss6kkycss with a Samsung ice maker model DA97-07365A the problem is it is not making any ice and the water dispenser is working fine
-Make sure turn the ice maker " ON"
If it's on then the Water valve to the ice maker might not function.
Good luck
Mai
Oct 26, 2017 | GE Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
The Water Dispenser suddenly stopped working, Ice will dispense ,however no water. GE model GSL25JFTAB5
It tends to be the problem of the valve. Connection is not proper it is not allowing water to ice maker. The valve can be checked with a volt/ohm meter if you.
You can ohm the solenoid of the valve and see if the circuit is open. You can also use the meter to check voltage to the water valve when the ice maker cycle starts. No voltage if the ice makes cycles or if the ice maker never cycles would indicate a problem with the ice maker.It tends to be an open solenoid circuit in valve.
Hope this helps.
Please feel free to ask us if you have any further queries.
Shane
Apr 24, 2011 | GE Refrigerators
Water is not dispensed, but ice maker works. This keeps happeneng . what can i do myself? model number GSH22JFRE SERIAL LH206147
It appears that GE has a problem with the water line to the water dispenser freezing up. I solved the problem by turning on the light on the dispenser. (Note, it is not an LED bulb). After about a day and a half the water began to flow again. Have not had a problem since then
Feb 16, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Water not dispensing
Most likely your water control valve on rear of refrigerator has failed. Do this pour tap water into the ice maker make sure it is on and let the water freeze. If the ice drops and does not refill then the water control valve is the problem. If ice maker does not cycle then it is the ice maker. Find your model number around the door frame and tell me which model GE you have and I will tell you the replacement parts. Let me know, Thanks, Sea Breeze
Nov 19, 2009 | GE Refrigerators
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22JSRE Refrigerator Ice / Water Dispensing Issue
I have the same issues as above, ice maker makes ice but will not dispence or give water,
when I push the lever to get anything the lights go out and the fans slows or stops until I let go of lever.
Side by side GE : Model # GSH25KGRE WW / Serial # MG278521
has anybody else had this issue with this model?
Feb 02, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
