Question about Hotpoint HSS25GFP Side by Side Refrigerator
Water to door stopped. I replaced filter. Still no water to door.
  • Hotpoint Master
  • 2,330 Answers
The line could have froze in the door,or you have a bad water valve,go to the back of fridge,disconnect the water line and hit the dispenser to make sure it's the valve,if water comes out you know the line is iced up,if it is you can use a hair dryer and heat up the door where the bottom hindge is half way up the freezer door and hit the area where the ice dispenses out the door,
Posted on Jan 30, 2010
After replacing filter, ICE dispenses ok, water not. FED from same water filter.
Check for water at the connection under the door. If you have water the tube in the door if possibly frozen. If not, its possible you have a bad water valve, But you need to check to make sure first, don't spend money on parts before checking. Good Luck
Apr 15, 2016 | Refrigerators
Water dispenser only drip water
If you have a inline filter on its about stop up need to replace it. If you don't have one then the filter on water valve is stopping up. You need to turn water off going to ref. and take water line off and clean out filter inside water valve then put it back and it should work fine after.
Apr 18, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
Not making ice after changing filter.
Hi and welcome to FixYa I am Kelly.
A new filter can take several cycles of the ice maker to fill the filter up with water before. The average filter is around 30 oz and the average ice maker fill cycle is 3.2 oz. The new filter did not have any water in it. The water in the door has a resercoir so the air in the filter will still make the water work until you get air. Drain abour 3 tall glasses from the water in door. The ice maker should then work properly. The filter filters water for water in door (inside) and the ice maker so if you have water inside the door you should have ice UNLESS one of the inlet water valve solenoids has failed. Also make sure the Freezer door / light switch functions properly. The door switch is supposed to stop water and ice functions with the door open.
I would like to know if it starts making ice.
Thanks for choosing FixYa,
Kelly
Jul 26, 2011 | Jenn-Air JFC2089HE French Door...
The icemaker does not work and the water in the door has stopped. The last time water came out it looked colored. Is there a filter that I am supposed to replace? If so where is it?
some models do have a water filter, which is either located at the bottom outside of the ref. on the kickplate,(grill), or inside the ref. itself on the ceiling. If both water to the ice maker and the drinking water stopped at the same time that is more than likely the problem.
Nov 07, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water stopped working, ice working on door
Have you changed your filter? Make sure to change these every 6 months, I believe. Also, if your filter is new/ or within the 6 months, you may have a water valve issue. You'll need to replace the water valve, which is on the back of the unit, towards the bottom, behind the panel. You can remove the panel, its all Phillip screws.
Mar 27, 2010 | LG LFX25960ST Stainless Steel French Door...
Refrigerator does not produce ice or water. Kenmore Elite Refrigerator Model Number: 795-775-69600
If you have both ice and water stopping you have a water supply issue.
Water enters under city pressure through an eighth inch supply line.
Start simple and work from there.
If the fridge was moved the line can get kinked. Slide the fridge out and check you have water to it. You can loosen the supply line connection just a little and you should see water leaking. If not it is a plumbing issue in the house. Most likely a the supply line is kinked or possibly someone closed the shutoff valve to the fridge.
OK so we have water to the fridge.
Water comes in and connects to a water filter and then to the door.
If the filter is badly clogged it can cause low pressure to the door and that would cause the problem. Check the filter.
If no go still then check where the water is stopping.
Remove the from cover from under the unit. That is the plastic grate at the bottom of the fridge. It will just pull off but be gentle and take your time so as not to break anything.
Water supply will run through a clear plastic hose. It runs to the filter then to the bottom of the freezer door and up through the door.
You can sometimes see where the water has stopped and clear or replace parts as needed.
There is a connection just before entering the door from the filter. You can loosen that to see if you have water to that point.
If you have water past the filter the problem is in the ice maker and water supply inside the freezer door. Water can leak here, expand, and crack plastic parts easily.
If there is water to the door then you need to dig into that. This gets a little more complex to describe but in short take the ice maker out and check for water supply or broken parts. The problem is probably before the ice maker as your water in the door is not working. This indicates it is not just the ice maker.
Hope this helps.
Mar 12, 2010 | Kenmore Refrigerators
Water dispenser stopped working
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Dec 13, 2009 | Washing Machines
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
107 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
