Question about Canon P1-DHV Calculator
How do you load the printer paper in P26-DH III
The feed slot is located in the rear of the unit. You don't feed the paper down from the top-there is a paper slot in the rear; just cut the paper at a 90 degree angle and feed it into the rear slot-very easy. I tried to feed it down from the top for twenty minutes and then discovered the other slot. Good luck
Posted on Mar 22, 2010
3 Suggested Answers
SOURCE: p26-dh III - I am also unable to load the printer
It is necessary to feed the paper through a slot on the back of the printer in the dark gray area. Feed a single paper through and push the FEED button. When you see it appear, feed the paper through the clear serrated slot on the top cover over the printer.
Posted on Mar 31, 2010
SOURCE: installing new paper in canon p26-dh ii
looked over P1-DHV Calculator found slot on top back middle of machine where paper goes in easy then up into machine with paper feed
Posted on Jan 06, 2010
Paper won't feed into slot on Canon P26-DH 111
Could not find anything directly about a Canon P26-DH III calculator but, here are steps I found for a similar model. Please let us know if this does the trick for your situation or not. Thanks & Good Luck.!
Installing a Replacement Roll
Move the power switch in the upper right corner of the calculator to the "Off" position. (or wherever it may be on your model)
Push the wire roll holder back so it protrudes from the back of the calculator. Place the replacement roll on the holder so the paper's end extends from the bottom of the roll.
Cut the paper's end diagonally and insert it into the slot in the back of the calculator.
Step
Move the power switch to the "PRT" position to turn on the calculator.
Oct 14, 2017 | Canon Office Equipment & Supplies
How do you load paper into a canon p23-dh v
For loading paper into canon p23-dh v is to cut a piece of index card to the length of 3 inches and to the width of the paper you want to load. Tape evenly to the end of the paper roll and put into the ****, pushing gently in and at the same time pressing the 'Feed" button. It will immediately feed since it is firmer than the Poat-it paper.
Apr 26, 2010 | Canon P23-DH Calculator
P26-dh III - I am also unable to load the printer paper. I can't figure out how it is to be fed in.
Mar 18, 2010 | Canon P1-DHV Calculator
Loading paper into the Canon P170-DH Desktop adding machine
Rather than try to describe the process in words ("lift up the arm, then feed the paper through..."), I'll point you at the illustrated instructions in the manual at the manufacturer's web site: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=349&modelid=9785
Mar 03, 2010 | Canon P170-DH Calculator
How do i put recept paper in my canon p26-dh 111
how to replace the ink roller on a Canon P26-DH 111
calculator?
Jan 23, 2010 | Canon P1-DHV Calculator
Installing new paper in canon p26-dh ii
Jan 05, 2010 | Canon P1-DHV Calculator
I cant' get new paper installed on desktop calculator
There is a small **** right where the paper roll gets installed - it looks like the seam between the top and the bottom of the calculator. The paper feeds from the roll directly into this - maer sure you have a very clean edge to start with - then turn on the print function and push a button until it starts to feed through. Be patient with it but it will work.
Dec 20, 2008 | Canon BP120 DH Calculator
Canon p23-hd v
download the user manual (P23-DH III) from here:
http://rapidshare.com/files/181603396/P23DHIII.PDF.html
Dec 04, 2008 | Canon P23-DH Calculator
Canon P1-DHV Calculator Logo
4,035 people viewed this question
old marine
old marine
