Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
How do i connect my second computer to my westell 327w
  • 2,263 Answers
Is it a wireless computer or the wired computer?
I believe the main computer is online.
Check the settings on the router.
You will need to open the router set up page.
here you will see the settings of the router.
If you are trying to connect to the wireless network then make sure that you are typing the correct network key.
Click here for more information about routers and network
Posted on Jan 30, 2010
SOURCE: VPN through Westell Versalink 327w
ok use this to goet to you setup
http://dslrouter/
and then use this to open ports but you have to chose the program you want to omp it for
http://www.portforward.com/english/routers/port_forwarding/Westell/Versalink-327W/Versalink-327Windex.htm
Posted on Nov 21, 2007
SOURCE: hook up westell 327w to linksys router
I had same problem 2 months ago where my hp laptop would not
connect to westell 327w. I found solution at verizon web site,
they had an update for the westell modem. After the update my
laptop connected to the westell modem no problem. A router was never needed.
Posted on Feb 19, 2008
SOURCE: westell 327w
Your router is for DSL not cable
Posted on May 01, 2008
ayamaya
  • 143 Answers
SOURCE: westell model 327w
you can run another ethernet cable from your westell modem to your laptop. hence, if you want your laptop to connect wirelessly, it must have a wireless card/adapter inside. if it already has a wireless adapter, it should automatically detect your wireless network and you just need to connect to it (note: you need to enter the correct wireless security/network key if you have enabled it on your modem). by default the serial number is the ssid of the router and the wireless security is disabled. but if you are not sure of your wireless security, log on to the modem's web user interface by typing http://192.168.1.1 on your web browser's address. then go to the wireless section and verify your wireless settings from there.
hope this'll help you.
ciao!
Posted on Aug 20, 2008
dante777
  • 623 Answers
SOURCE: Want to use westell 327w as access point only
Yes, you can try to set up your network as follows:
  1. Unplug the second (Westell) router from anything and power it on.
  2. Reset your second router. Press and hold the Reset button on the router for 10-30 seconds. This will return the router to its factory settings and avoid any complications from the set-up you might have had when the router was being used as a primary router
  3. Connect one computer to the router. Do not connect the second router to the first at this time!
  4. Configure the second router at http://192.168.1.1/ (Check you manual for details. Usually the username is "admin" and the password is either blank or "password".)
  5. Change the LAN IP address of the second router from 192.168.1.1 to a free address within your LAN (see what IP range is used by your first router! If it using the same range (192.168.1.xxx) then 192.168.1.2 should be O.K.). The address you change to (192.168.1.2) must not be used by any other device with a static IP address in your network nor should be assigned by the DHCP server your network. A default Linksys router uses 192.168.1.1 itself and the DHCP server assigns 192.168.1.100-149.
  6. Turn off the DHCP server on the second router. (This is important, otherwise you end up with IP conflicts!)
  7. Save your settings.
  8. Unplug the computer from the second router.
  9. Connect an Ethernet cable from a numbered LAN port of the first router to a numbered LAN port of the second router. Do not use the Internet/WAN port on the second router!
  10. Start up the first router if necessary and reboot the second one as well.
  11. Voila!
The only problem I can see here is that your first router - now in charge of security - does not see your wireless clients as wireless, because they connect via an Ethernet port. Because the second router is connected via a LAN port, it is not using the router functions (DHCP, security, etc.) That might be ok with you - I'm just pointing it out.
If this doesn't work for you, just come back here, leave a comment and we take it from there.
Good luck and thanks for rating!
Posted on Apr 02, 2009
Do i need a wireless router if i have westell 6100f
Yes. The Westell 6100f is not a wireless modem, therefore, you will need to get a wireless router to connect wireless computers.
Or if your ISP is Verizon and you want a wireless modem/router, you may contact them and replace the Westell 6100f with a Westell Versalink 327w, or Westell 7500, or an Actiontec.
Hope this helps!
Mar 01, 2010 | Westell Wirespeed LiteLine 6000 Modem
Westell versalink 327w from bellsouth can't connect
Howdy,
I do not think this modem will work for you. Contact O.T.C. to be sure. For a few details...
I presume that you can access your Westell wireless modem/router 327w with the IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. If you see the Bellsouth FastAccess Internet Service logo then you know you definitely have a Bellsouth modem.
Now, let's presume, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, as stated above, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with orlando telephone company but I do not know if it will work. (Doubtful...) I use the Bellsouth 327W and it is GREAT. (With Bsouth/ATT) Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
Good luck,
J
Oct 07, 2009 | Westell Wirespeed VersaLink...
I have switched to a Westell VersaLink 327W from a older Westell Wirespeed. The Wirespeed communicated via USB and the new Westell communicates via Ethernet. How do I get the computer to see the modem?
If you are using a Westell DSL modem with ethernet connection, then you connect the modem's ethernet port to the computer's network card. This also uses an ethernet cable. Good Luck
Jul 19, 2009 | Westell Wirespeed VersaLink...
Can connect only one computer at a time over westell 327W modem
Try this, go to network connections, right click on your connection, click on properties, where it says this connection uses the following items, scroll down to internet protocol, highlight it then click on properties below it, make sure Obtain IP address automatically is checked. do this on both computers. Let me know if it works. lone99star
Jan 15, 2009 | Westell Wirespeed VersaLink...
Hi I can only use the Westell 327W with DSL
This Westell 327W can only be use with a DSL internet connection since this is a DSL modem..
Hope that helps.........
Sep 19, 2008 | Westell Wirespeed VersaLink...
Westell 327W & Verizon DSL
I have centrytel DSL and westell Model 327W
Sep 09, 2008 | Westell Wirespeed VersaLink...
Westell 327W (Versalink)
you want to setup a peer to peer network using a workgroup. File sharing must be enabled in XP and Vista in order to share files. Temporarily disable the firewalls in Windows when setting up the shares....search on the Internet for setting up a Workgroup in XP
Jul 01, 2008 | Westell Wirespeed VersaLink...
Westell 327w
xbox live connection test MTU failed
Mar 12, 2008 | Microsoft Xbox 360 Console
do you have login access into the Modem/Router?
if yes, look for port forwarding and set it to your IP of your computer. open port 500 or what ever is required by MS fro the VPN
Nov 01, 2007 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
119 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
