Question about Kenmore 22.0 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
My Sears Coldspot Refrigerator side by side 106 series ice maker is not working water cold water side is working.I have not change the filter iI have no manual
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
  • 93 Answers
SOURCE: We have a Kenmore Coldspot
It is probably your defrost cycle causing this. Obviously if you shut the water line off then it is not coming from there so there is only 1 other place it could be. Every 8, 10, or 12 hours depending on you defrost timer the refrigerator will defrost itself.......the frost melts into water and drains into a pan under the fridge. If the drain is plugged then it will just run into the refrigerator. If you have a freezer on top model then just remove the back wall inside the freezer, it will be a few 1/4 inch screws....If you have an icemaker then remove that too, it will be held on with 3 screws. Just look behind that wall and you will probably see ice at the bottom.....defrost the ice and pour a cup or 2 of water into the drain to make sure it is unclogged. If it is still plugged up then you have to find the clog....either in the back of the fridge behind the lower cover or in the refrig compartment near the back of the roof.
Posted on Sep 12, 2009
rogrrabbit
  • 986 Answers
SOURCE: Oue Kenmore Coldspot ice-maker quit working. Any
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Posted on Nov 11, 2009
SOURCE: kenmore side by side refrigerator
there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
Posted on Dec 22, 2009
toolkits
  • 1099 Answers
SOURCE: Hi, I have a 2003 Kenmore
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Hope this helpout.......
Posted on Jul 29, 2010
I have a Kenmore Coldspot Side by side refrigerator model 58787892. The ice maker is not making ice. The mechanics of the maker work but it does not fill up with water. The filter is changed regularly...
check to see if the ice tube going into the ice maker is frozen up. you may have to thaw it out to get water to reach the ice maker again. lmk if that's not it
Aug 05, 2013 | Refrigerators
Kenmore coldspot model 106 9445781 the icemaker motor makes loud noise. Sounds like its under a heavy load.
Suggest you take the ice maker out and defrost it. You propably have ice crystal buildup and causing it to labor harder.
Jan 16, 2012 | Kenmore Side by Side Refrigerator
Kenmore Coldspot Ice Maker Modle #106 56622500 I
these have to be in correctly to lock back in and allow the unit to function. Try removing the bin again and be sure there isn't any small pieces of ice trapped anywhere. Also make sure there aren't any broken pieces from the bin. Hope this helps. Good luck.
Aug 18, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water collecting in bottom of freezer
Your seal may be bad letting in moist air that provides a source of water to condense on parts of the freezer.
Jul 24, 2010 | Kenmore 53703 / 53706 Stainless Steel Side...
No ice is being made.
Most likely either water valve is bad or ice maker is bad. You would need to determine if Ice Maker is sending voltage to water valve. If it is, replace valve. If it's not, replace ice maker. Also be sure filler tube going through back wall is not frozen. If it is, replace water valve.
Sep 02, 2017 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore coldspot refrigerator model #106 RUMBLING!!!
Does it have automatic ice cube maker not hooked up to water? If you do make sure thin stainless bar isn't straight down. on the side of ice maker.
Nov 15, 2017 | Kenmore Refrigerators
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Ice maker not working, light blinking
I contacted Sears repair service and had the Ice maker and control panel replaced.
Jan 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerators Logo
191 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
