Question about Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi
Added remote starter on vw jetta 2004
Car will start sometimes and sometimes it doesn't with the remote starter. Seems like when the temp. is below 30 degrees the car will not start. It tries but won't start. This is when we'd like to use the remote! The guy who installed said this might happen because "that's the way vw's are"! He told us this after he installed. Is this the case with the vw's? Any suggestions?
  • 344 Answers
No, this is not correct, did you have to give up a key, or did he use a bypass module, either way, you can check next time it won't start by putting your key into the ignition and leaving it in the off position, then try to remote start it, if it starts then your installer needs to reposition the transponder loop around the ign switch or reposition the "key in the box"
Posted on Jan 31, 2010
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
2004 Vw jetta tdi below 32 degrees starts then dies
Sounds like the fuel is freezing try adding a small amount of petrol to the diesel
Nov 23, 2014 | Cars & Trucks
Valet Key Doesn't Start Engine
Sounds like the chip in the key is not allowing the security system to allow the car to start. You may need a new key from the dealer.
Jun 25, 2012 | Volkswagen Jetta Cars & Trucks
2002 vw jetta vr6 no start no crank, but able to pop start
Start by checking the switch above the clutch pedal ... I have seen where they come loose, brake or move and when you push in the clutch it doesn't engage the safety switch all the way.
Nov 05, 2017 | 2002 Volkswagen Jetta TDI
1997 VW Jetta GLX Had problems with the car starting. Hear nothing, no sound from the engine at all. Replaced the starter recently. Had some success with starting the car, however; Jetta seems to not...
Behing the ignition barel you have contact plate with plug.Change it.There is special tools to remove the wheel sreering column bush.Go to VW garage.
Jun 14, 2011 | Volkswagen Jetta Cars & Trucks
I have a 2004 VW jetta turbo charge start but dont run what could cause that
unlock car with key/hold key over,windows will go down.lock carhold over,windows will go up.sunroof will shut(if fitted).then press/hold unlock button on remote for 30 secs then start as normal.(you have just reset the immobiliser system.
Oct 27, 2010 | 2004 Volkswagen Jetta
Need exact location and picture of coolant temp sensor on tdi vw jetta 2004 please Thanks
The exact locations and picture of Engine Coolant Temp (ECT) sensors on 2004 VW Jetta TDI:
1. ECT sensor 1 placed on cylinder head:
2. ECT sensor 2 placed on the left bottom side of the radiator:
Sep 21, 2010 | 2004 Volkswagen Jetta
1996 vw Polo classic 1.8i delay on activating starter
check for loose starter wire at starter motor large one from batt to post 13 mm socket should do it
Jun 07, 2010 | 1996 Volkswagen Jetta
I have a 2004 VW Jetta tdi and teh starter does
jump the starter or hit it with hammer if it starts starter is bad replace starter
Feb 21, 2010 | 2002 Volkswagen Jetta TDI
VW Golf starting problems
Most likely, the problem is the wiring. Over the years, corrosion builds up in the ground strap and positive lead to the starter (from the battery).
or the battery is old or the the starter is dying get it test at a shop for free.
Aug 28, 2009 | 2001 Volkswagen Jetta TDI
Check engine light on for sometime; Response to throttle sluggish
If your catalytic converter is "below efficiency" or otherwise clogged, you will lose power as you drive and the vehicle heats. The more you drive the vehicle, the worse the problem will become. The exhaust can't escape properly through the catalytic converter, therefore your engine won't run properly. Your issues are related, and if you replace your catalytic converter they should go away.
May 26, 2009 | 2001 Volkswagen Jetta TDI
Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
204 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
