Question about Hitachi 57SWX20B 57" Rear Projection Television
Picture loss when I turn on the TV it works fine for about 4 minutes and then the picture disappears, only the sound stays on.......help
    Novelist:
    Champion:
  • 211 Answers
It sounds as though you have what is referred to as a climental problem. In laymen terms, a transistor, chip or regulator is heating up and breaking down. The way a technician normally isolates this type of problem is by using a cooling agent ( freeze spray ). When the set heats up and the picture goes away, the technician sprays some of the cooling agent on a part of the board ( select a small area, about 6 inches square ) at a time and see if the picture comes back on. When you do finally get to the bad area, the picture should come back on for a short period of time until the bad part heats up again. After a period of time and by using the freeze spray, a person can isolate the exact bad part. Replace that bad part, and any filter capacitors hooked to that bad part and the set should work properly. As always, use caution and unplug the set before opening the set and when using the freeze spray, be sure not to touch any connections in the tv as they could produce shocks.
I hope this has helped and good luck on your problem.
Ed
NC Electronic
Mills, Wyoming
Have a Great Presidents Day
Posted on Feb 18, 2008
Tv turns on, picture disappears after a few seconds, turn off tv, and then on, same problem picture is fine, the disappears after a few seconds
You may have either failing 24vdc power supply or the backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 07, 2010 | Televison & Video
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
RCA TV, model number 32V550T. No picture but sound is fine.
hiya
this sometimes is quite simple to fix as it cud be a dry joint on the circuit board where the tube motor sits.
or it cud be the tube is on its way out, which wud be cheaper to buy a new tv rather than have it fixed
rik
Feb 24, 2009 | RCA 32V550T 32" TV
Picture loss!
It sounds like cold solder joints on the vertical IC chip. Not a major deal. The entire board should be looked over for other joints becoming cold.
Mar 12, 2008 | Toshiba 35AF44 35" Rear Projection...
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Intermittent loss of picture
You'll have to locate the vertical output IC which should be mounted onto a heatsink, then take out a good magnifier under the printed circuit board and examine the solder connections on the pins of that IC and resolder the ones that are cracked.
Mar 12, 2007 | Proscan PS27125 27" TV
Sony KDL-40S2000 Picure Disappearing
hello, Check for trapped wires under earth of G2 board (top right).
Jan 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Picture Disappeariing
How many flashes are happening? If its 4 then maybe a bad panel.
Hitachi 57SWX20B 57" Rear Projection Television Logo
88 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
