I have tried to set this up several different ways. I used the dvr position on the back of the receiver and get audio but not video on the tv. I have the receiver set to HDMI 1 with one hdmi coonnected to tv. I have a cable box and DVD player set up to just the receiver and they work fine. Please help.
  • mjmbabb1976 Jan 30, 2010
    This is for my nintendo wii. Any more suggestions? THe tv is fine but my wii video won't show up on tv.
    How do I change the resolution on my samsung lcd tv?
  • 4,889 Answers
The DVR Is set to a different video output resolution than the tv. For example if you are using 1080i on the tv, the output settings on the DVR should also be 1080i. Anything more or less you will have sound but no picture.
Hope this helps,
Sai.
Posted on Jan 30, 2010
  • eagle338
    eagle338 Jan 30, 2010
    It applies to all HDMI based devices. The default output on wii 480i or 480p. Change your tv settings to the same and you will get video.
    Sai.
  • eagle338
    Since you have accepted the thread you may not be able to post further comments on it. Please mail your tv's model number to my ID- vls_powerful2002@yahoo.co.in and I will see you through this problem.
    Sai.
I need to know what model of a Motorola DVR is compatible with my receiver. What model can connect DIRECTLY from it's audio output to the audio input of my STA-795 Optimus Digital receiver (not through the...
Do you really have TV Audio OUT to a DVD (last sentence)?
Most DVR's have digital and analog audio outputs. Since every device they are intended to feed would have its own volume control a DVR output volume control might be redundant. Treat a DVR like any other audio device. Connect it to any available input on the receiver EXCEPT PHONO.
If you run the audio from the DVR (and EVERY video source) directly to the STA-795 you can bypass the TV and its questionable audio electronics (yuk). You can split the analog output of the DVR with y-cables and run it from the DVR to TO the TV for casual viewing and listening through the TV sound system (news, Oprah, etc).
Apr 21, 2011 | Optimus STA-795 Receiver
I have a SA 8300HD cable box connected to Yamaha RX-V2500 receiver using Digital Audio Out from cable box to DVR/VCR2 on the receiver. It had been working for 2 years. Then this past weekend it stopped...
Pretty good problem description.
Make sure the DVR/VCR2 digital input is assigned to the Cable box.
When the DVR/VCR2 input is selected do you get any front panel indicators on the Yamaha that indicate a good digital bitstream?
Try swapping the cable box output to the working DVD In connection to isolate it to either the source or the receiver's ability to decode it.
Check the audio output settings for the Cable Box, too. Sometimes their outputs are adjustable. It may be muted or set too low.
Mar 31, 2010 | Audio Players & Recorders
I have a vip622 with hdmi hooked up. no video or audio
Get a replacement receiver and see if this does not resolve the issue. I expect it will though. In the interim try a different port on the tv if you have multiple HDMI inputs and another HDMI cable if you have one available just to ensure that our suspicions are correct.
Thanks for using Fix Ya and being a valued Dish Network customer.
Mar 28, 2010 | DISH Network ViP622 DVR DTV Receiver /...
I just purchased a denon avr-1610 receiver and I cannot get picture back to my tv through the hdmi. I have a starchoice dvr which is dvi to hdmi, I come out of my satelite into sat/cab then out of my denon...
One possible reason is the HDCP (copy-prevention)-encoded signal from the DVR, which will transmits through to one device (the receiver) but not to a second (the TV). As an experiment and a possible solution, try reconnecting the HDMI cable from the DVR directly to the TV (provided you have an extra HDMI input on it), and using the component-video or S-video plus either digital or analog audio outputs to connect your DVR to the receiver. If this works, I think that the HDCP is the problem and this is the only solution.
It may be a little inconvenient to remember to switch inputs on the TV as well as the receiver, but you could probably program your remote with a macro to do both. The component video (or, more likely, the S-video) is also the best possible video signal you can use for dubbing to any DVD recorders, if you have one connected to the same receiver. You can still keep the HDMI connected from your PS3 (or other BD/DVD) player to the receiver, and from there to the TV, since that does seem to work -- if you don't mind turning on the receiver every time you want to watch a BD or DVD. My recommendation, however, is to connect all your video signals directly to the TV via HDMI or component, and use the receiver only for audio, or for switching of lower-level video signals like S-video that you can use for dubbing. That way you can always check the DVR or BD or DVD quickly without powering up your receiver, which takes a few seconds and much more power.
Feb 13, 2010 | Audio Players & Recorders
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Setting up DVR, Receiver & VCR w/out cable box
For TV audio thru the receiver, you will need to run an optical cable or RCA analog audio cable from the "Audio Output" or "Monitor Output" on the back of the TV to the CBL/Sat input on the Yamaha. The VCR goes to Video 1 on the receiver and the DVDR will go to DVR/VCR2 on the receiver. If you want to pass Video thru the Yamaha to the TV, use the "Monitor Output" on the Yamaha if it's at least "Component Video" if not, connect your video sources directly to the TV and audio to the Yamaha. Hope this helps. If you need further assistance with this, post a comment and I will help you further.
Sep 26, 2009 | Yamaha HTR-6030 Receiver
I have model number AVR587 Dennon receiver which worked fine with my nonHDTV; however, I just purchased a new HDTV and since the receiver model does not have HDTV the audio goes through the DVR. The...
it sounds as if your using HDMI out of the DVR to the TV which is fine but the better way to do this is to use the Component connections (red, Green, Blue) plus optical or coaxial from the DVR to the reciever and Component connections (red, Green, Blue) out of the reciever to the tv
Jun 27, 2009 | Denon Audio Players & Recorders
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
Echo effect when viewing movies/tv
Salutations robert42,
Usually echo effects could be the cause of some type of simulated surround or digital processing effects. Its more noticeable with some television broadcasts then others. I would try and deactivate any processing effects and see if this improves your experience.
Hope this helps.
Jon
Go Ahead. Use Us.
Jul 10, 2008 | Audio Players & Recorders
Dvr-s150 to dvd player
video cable has to goto the tv
audio can go to the receiver i have mine set the same way
May 27, 2008 | Yamaha DVR-S150 DVD Player
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
