Question about Tefal Aquaspeed 170 Iron
Insufficient steam I have a new Aqua Speed 170, it worked fine for the first few times but now I beleive there is very little steam being produced. I have cleaned as instructed to no avail. Can you advise?
    Genius:
  • 1,019 Answers
Try a commercial De-Scaler.
If your in a hard-water area. the iron will be heavilly scaled-up.
If there is a steam surge button, on the iron. Face it downwards and push the button several times.
Mike @ Compurepair.
Posted on Feb 22, 2008
Why has my Perfectcare aqua stopped emitting steam
You should hear the boiler heat up the water. When you pull/push the trigger, a pump should be activated and steam should be released. If the pump is not working, it could be a defective capacitor according to this article:
https://lieven.kks36.be/2016/06/11/philips-perfectcare-aqua-does-not-pump-solved
A spare capacitor should cost you no more than a few dollars, just find somebody with electronics/soldering repair skills.
Aug 31, 2014 | Irons
Euro-Pro X
Check the hose for something clogging it. It will be past the flattened area (by that I mean further from the steam cleaner). It sounds like something got stuck in the hose, and as the steam cleaner kept sucking on the hose, it caused the hose to flatten.
Sep 08, 2007 | Euro-Pro Steam Generator EP8001 Iron
Plug iron in but its dead
follow the next steps and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord +thermical fuse with VOM . Also test and, if needed, adjust calibration of the thermostat (
Nov 14, 2012 | Tefal Pro Express GV 8120 Iron
Steam escaping?
do the following step:
1) distilled water and softened produce leak , change the water
2)put water until the LEVEL
3)give time enough thermostat for heating. if you use before to HEat enough produce leak.
4)switch dial off to test the water stop leaking,when the steam setting is NOT working.
5) shake back and forth for a few time, to turn on back it is auto-off function.Can be leak when is auto-off mode
God bless you
Jul 14, 2012 | Irons
Good day I have an euro pro iron and it leaks all the time leaving water on washed clothes.also it leaks out of the bottom??
The water may come out at the bottom instead of steam. this is due to insufficient heat produced. So switch on your ironbox and keep it in full temperature using the knob. then the water will be coming out as steam and not as water itself. Try again.
I hope this is useful to you
Thanks
Jun 27, 2010 | Sunbeam Euro Press 4045 Iron
My polti 750w mod PRO VT doesn't produce steam
i woundnt see why not alls that needs to be done is replace the power cord to the unit your local electrician store should be able to fix that
Apr 21, 2010 | Irons
My tefal aqua is not taking out creases but i can see steam coming out of the iron I have tried the instructions according to the manual for cleaning but still no good please help
Some creases cannot be removed with any steam iron.
Dampen the area with the creases or place a wet press cloth over the area and try again.
Feb 20, 2010 | Tefal Aquaspeed 170 Iron
My new laurastar steamer is not producing steam at
plse call customer service on 1800 999 910
Nov 13, 2009 | Irons
MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
Jul 25, 2009 | Rowenta DX6700 Iron
Tefal Aquaspeed 170 Iron Logo
236 people viewed this question
Top Tefal Irons Experts
Billy Detlefsen
Are you a Tefal Iron Expert? Answer questions, earn points and help others
