Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Have kenmore elite trio model 596.73502201 blows cool air not cold, no frosting issue what gives?thanks
  • 15,935 Answers
It appears your thermostat or evaporator fan has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
2 Suggested Answers
justinbur167
  • 257 Answers
SOURCE: I have a Kenmore Elite
Hello Joanispud,
I understand that you are having a problem with you Kenmore Elite Fridge. You state that the bottom freezer is working fine. However, the top section the fridge is not cooling at all. There are a few possible solutions that can cause this problem lets see if we can not go over them and fix the problem that you are having.
First thing I would check is the evaporator fan. The fan is located at the rear of the top of the freezer section. The fan circulates the air from the freezer thru the evaporator coils and up to the fridge to cool it. You will be able to hear or possibly feel the air circulating in the freezer. If it is not you will need to remove the drawer unit, remove the rear cover panel to access the fan. This will require a 1/4 nut-driver or 1/4 socket and ratchet. The fan will have three wires the only one that has to be put on the same place is the ground (green wire). I have located the evaperator fan at partselect for $36.18 part #2003659, at the following link http://www.partselect.com/PartDetail.aspx?Inventory=2003659&SourceCode=7&ModelNum=59673502201
The other possibility is the condensor coils are dirty. The coils are located at the bootom of the unit. The collect dust and dirt and should be cleaned twice a year. The things you will want to use to clean it is a long skinny brush and a vaccum with a crevis tool. Brush and **** as much of the dirt as you can from underneath of the unit. This will also help to make you compressor run cooler and last longer, as the unit will be able to remove heat faster.
More than likely the problem is the first one. However, you should still clean your condensor coils as stated above it will help your unit to survive alot longer. If you need in futhure assistance please do not hesitate to post back to this thread I would be more than happy to assit you in any manner that I can.
I have also located you a door switch with a video that you can watch inorder to change it out. This will stop you lights from being on all the time as the switch is no longer closing the circuit. The switch #937, cost $10.35 and is at the follow site with the video http://www.repairclinic.com/Refrigerator-Switch-Parts?s=t-596+73502201+-%3d%3da4c35 the switch at the top of the page with video.
Thank you for choosing FixYa.com
Justin
Posted on Apr 03, 2011
My refrigerator Kenmore model 795 77563600 freezes up the vegies on the left side drawerand werever I store on top of that drawer. What can it's wrong with it?
Your refrigerator as cooling tubes that allows the cold air or the freezer to go to the refrierator side. If one becomes blocked with frost all the cold air is then forced to route through the other cooling tube. And that what it sounds like is happening to you.
Jan 04, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore trio freezer is cold, but not the refidgerator is not, and there is frost and ice where the cold air blows in from the freezer.
Since Kenmore is manufactured by several different manufactures, you should find the model number off the equipment id tag and provide that so I can give you the best advice. It will probably be located beside the vegtable tray in that unit, but not always.
You have a defrost system failure. Your defrost system is made up of the defrost heater, defrost thermostat and defrost timer/control board (newer units have incoorporated the timer onto the control board). You will need an ohm meter to check the heater (if it isn't open - it is good) and the thermostat (low ohm reading normal 28-38 ohms) but the timer is a different story. So you will need to rule out the heater and thermostat before replacing the timer/control board.
Sep 30, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
We have a Kenmore Elite Trio (bottom freezer- Model#596 73502201-bought 2004) and both the fridge and freezer are blowing cool air but not cold. Food in freezer has defrosted and the fridge temp. is much...
Check to see if the evaporator behind the back metal cover on the freezer side is all frosted up, if it is, then it will probably be the defrost heater which is bad and letting it clog with frost causing low or no airflow. The heater is not expensive and can be ordered online on ebay.
Mar 02, 2018 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator is not cold
Hi Louis,
This is what has happened. Due to the door being opened for so long moisture which is naturally in the air has collected on your freezer coils. What you need to do is turn the whole thing off for at least 24 hours. Open the doors and put some towels around it to let the frost melt out.
All the air that gets cooled in your unit gets cooled by a fan that pulls air through those coils. Once the frost has melted out of them it should cool just fine.
May 25, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite Trio Fridge Not Cooling
check the over-load/contactor on the side of the compressor,remove it and shake it if it rattles,replace it
Nov 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
1 year old Kenmore Elite Trio Refridgerator not cooling
There are a lot of things that could be the source of the problem... is there no cooling at all going on in the freezer? Is the back wall of the freezer cold? It could be anything from a fan, to the compressor, to the control board... you need a technician.
I would get on the phone with Sears, and explain the continuing problems you have been having, and they may agree to cover service.
Jul 26, 2009 | Kenmore 73503 Stainless Steel Bottom...
Freezer works, refrig does not cool
hi they only thing that could cause this problem is dirty coils at the back.clean all the coils at the back. thanks the appliance doc.
Oct 17, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
538 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
