Question about LG Washing Machines
My lg top loader washer continously drains water and never washes
My lg top loader washer continously drains water and thus doe not get to trhe wash stage. T8501TEPT
I was solve resolvbe it in a most simple way.
Posted on Jan 31, 2010
LG washer drains withour washing!!!!
Call LG customer service. The unit is probably still in warranty. If not contact a certified LG repair shop and have them come examine and if possible repair the machine.
Apr 09, 2015 | LG WFT1071TP Top Load Washer
Does this machine have a lint filter? I am getting bits of yuk on my washing after the wash is finished
No lint filter. The tumbling wash action generates very little lint, which washes down the drain.
To get rid of the "yuk":
Open the access panel on the lower left corner on front of the washer.
Use small hose to drain the remaining water from machine.
Remove the pump filter next to the hose, clean it out, and replace it.
Run the washer with a commercial washer cleaner such as Affresh, washer magic, or whirlaway hot tub cleaner, no clothes, hottest longest cycle possible. Use the tub clean cycle if your model has it.
Resume washing, using one tablespoon of HE detergent per cycle. Use only 1 teaspoon of fabric softener if you use that. These machines use much less water than the old top loader ones, and thus you must use much less detergent.
Feb 24, 2011 | LG Washing Machines
LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Apr 27, 2010 | LG WFT1071TP Top Load Washer
Machine does not drain and spin at end of cicle It is a LG top loader washing machine model R852
Your motor clutch is bad. That controls on the motor along with the timer on a washer from going to spin or agitate.
Dec 05, 2009 | LG Washing Machines
Do Frigidaire Front Load Washers require H&E detergents?
The answer is YES. Nearly all front loader washers built for consumers are rated as high efficiency because of the small amount of water and electricity they use. This small amount of water, coupled with a wash tub that does not agitate continously, followed by a high speed final spin of 1200 rpms or higher, all equate to an overall energy savings as compared to a conventional top loader. Regular detergent is formulated to be used in a wash tub with a 35 gallon capacity. So, if you use that same detergent in a wash tub that uses 5 to 7 gallons of water (such as yours), you are in effect putting about 5 times the concentration in the washer. This can lead to soap scum build up which causes odors, soap deposits that remain in your clothing and can cause skin irritation, "SUDS" errors that stop the wash program due to too much suds in the wash tub, and premature wear on the drain pump motor and seals. In fact, most front loaders will have a disclaimer added in the owner';s manual that explains this. Most manufacturers will also void the warranty if it is discovered you are using improper detergent. Use HE detergent and pay attention to the label. Some of them are double (2X) and triple (3X) concentrated. I hope this helps you.
Nov 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Water keeps draining LG WF-561SPP top loader
If the cycle does not stop draining that is usually because of a faulty membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Apr 02, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Hotpoint washer fills begins to agitate then refills continously.
Very likely your drain hose is set too low. You can solve this with a standpipe or a kit called a siphon break.
Dec 31, 2008 | Hotpoint VBSR3100GWW Top Load Washer
I have a Brand LG Top loader washing machine (Fuzzy Logic WF-T9235TP), it continue draining the water even if I am starting to wash
You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
Dec 20, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
211 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
