Need code for toshiba model 42hl67 tv - Televison & Video
5 Suggested Answers
SOURCE: 42hl67
make sure the power save setting is not on it turns the tv on slower > see if picture settings such as contrast and brightness are all the way up > or picture profiles are on right setting .e.g cinema is usually dark screen
Posted on Dec 07, 2008
SOURCE: I have the toshiba 42HL67 Tv and Need the Base
try toshiba.partstore.com
Posted on Feb 07, 2010
  • 159 Answers
SOURCE: my tv is a 42
Hi, I have looked into whether or not this t.v. is wall mountable. The only way to tell if this is possible will be to look on the back of t.v. and if wall mounting is possible then there will be 4 screw holes approximately 15 inches apart forming a square. If these " mounting holes are not present then there is no way to mount the wall bracket. Second if holes are present there may be a protective plastic cover at the top of the table top stand where it meets the t.v.. It more than likely is just a snap on type situation and a little bit of prying will pop it off revealing the screws. I hope this has been useful, and thanks for asking FixYa, Good luck- Prodzilla.
Posted on Apr 20, 2011
gopakumarg43
  • 74383 Answers
SOURCE: I have a Toshiba tv model# 42hl67 no sound.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Aug 31, 2016
Why is the t-con board in my Toshiba Reza 42HL67 LCD TV repeatedly dying?
Could be just bad luck! It seems unlikely to me that the power supply would take nearly a year to destroy the T-con board!
You could get in touch with Toshiba to see if there is some kind of problem that is cropping up on this model that might cause failure in on the T-con.
May 19, 2016 | Toshiba Regza 42hl67 42-inch 720p Lcd Hdtv
How do you change the time zone on 2007 Toshiba Regza 42HL67?
the manual doesn't mention anything about setting the time, so I am wondering if it comes from the cable or satellite box connected to it.
this is how it is done on another Regza model
Setting the time zone
The Time Zone setup will allow you to specify the
correct time zone for your region. This feature will
allow the TV status information to show the correct
time zone information for your viewing area.
From the SETUP menu, highlight TV Settings and
press T.
Press B or b to select Local Time Setting and press
T.
Highlight Time Zone and press C or c to set your
desired time zone.
If you want to activate the daylight saving time,
highlight Daylight Saving Time.
5
Press C or c to select On and press O.
Toshiba REGZA 46SV670U Owner Manual Setting The Auto Input Feature Setting...
your model manual
Toshiba 42HL67 42 LCD TV Service Manual
Jul 24, 2017 | Toshiba REGZA Televison & Video
My tv is a 42 inch toshiba model#42HL67 im trying to remove the base from the tv so that i can mount my tv
Apr 20, 2011 | Toshiba 42HL67 42 in. LCD Television
Tv seems to only have red and green colors
SOLUTION: Set "Option Data" and "Model ID Data" after replacement of the Main TN / AV Signal
PCB for then model being serviced. Refer to Service Instruction INST2007-040 Rev 1 after
replacement of the Main TN / AV Signal PCB
Dec 28, 2010 | Toshiba 42HL67 42 in. LCD Television
42hl67 has a continuous blinking yellow light in 3 blink intervals, how do I fix this?
I followed the steps at the following link and it worked for me. I have a 2007 Toshiba Regza 42HL67, but the firmware applies to many models as documented in the readme file at the location found via the link below. I used a 1gb SD card formatted FAT16, copied the unzipped files and folder to the card (wasn't sure if it required the top level folder or only the files under the top level folder so I copied both to the root of the SD card), unplugged the TV, inserted the card, plugged in the TV, waited 2.5 minutes, unplugged the TV, removed the card, plugged in the TV, yellow light flashed 3 times and went out. I turned on the TV and it has worked normally since last night.
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
May 09, 2010 | Toshiba 42HL67 42 in. LCD Television
42hl67
I had lcd 42" over a year it is working find before , but now it has very dark picture
can y help me to find out what is a problem and how much to fix?
May 01, 2008 | Toshiba 42HL67 42 in. LCD Television
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
