Question about Garden
I have a new 18'' craftsman, couldnt resist the price 42 cc, but i want a bigger chain, it has a standard 3/8 small chain for trimming branches, I know to do this will require a different bar and sprocket but noone seems to be able to find one, is this possible?
    President:
  • 2,220 Answers
Your saw is made by Poulan. It is model number PP4218Something. None of Poulans 42 series offer a bar longer than 18".
Oregon offers no bar beyond 18".
I did not see an adjustadle oiler, it is very possible the oiler will not provide enough oil to a longer bar. A longer bar might also be nose heavy and difficult to control.
You can find all poulan PP4218s here:
Poulan.com 14 different models by my count
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number (true of Poulan, no promises with Craftsman) is the type.
HTH
Lou
Posted on Jan 31, 2010
  • 66 Answers
Many time the big chain stores (like Sears, Wal Mart, etc.) will have products made to their own specs (re:cheaper), which makes getting replacement parts difficult at best and impossible at worst. Another reason they do this is so that you won't be able to find the exact same model elsewhere at a better price and force them to match or beat it. It's entirely possible that if you can't find the longer bar & chain at Sears, you won't find it anywhere.
Posted on Jan 30, 2010
The chain on my NEW STIHL 130 limb trimmer does not move when I accellerate the trigger. How can I fix this ???
Does this model have a chain brake? If so release it. If not check the chain tension and see if it's too tight. The chain may also have jumped off of the sprocket.
Mar 09, 2017 | Stihl Garden
What size bar and chain go on this for general crosscut work
the bar is determined by the engine capacity
small 35 cc engines run 350- 450 mm bar
bigger the engine the bigger the bar
as for the chain
the bigger the bar the bigger the pitch of the chain
talk with a shop that sells chain saws ( sthil--Mccolluck etc) and get the chain and bar suitable for the motor size
Nov 20, 2015 | Garden
Settings for carb. on a 42 cc chain saw
Initial settings are one full turn CCW on both low and high side adjustments.
Sep 02, 2014 | Craftsman sears 18" Chain Saw Chain (...
My 18 " craftsman chainsaw will not oil the chain.
Take the bar off and clean the grove out with something like a small flat blade screwdriver.Make sure its open where it bolts on.It gets its oil through the bolt holes.If you have a way to blow the dirt out it helps.You can try running the saw without the bar on to see if its putting out any oil.If not you will have to get to the oil pump to see if its not bad.
Mar 08, 2011 | Craftsman sears 18" Chain Saw Chain (...
What file size do I need to sharpen chain
It realy depends on the type of chain you have fitted, hobby chain fitted to small home owner saws is normally a 3/8 low profile and requires a 5/32 file, slightly bigger machines have a .325 chain and require a 3/16 file, big machines have a standard 3/8 chain and require a 7/32 file, the correct file should fit nicly into the cutter and sit slightly abobe, this will stop you file under the cutter head and creating a hook.
Feb 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have Poulan Pro 42 CC 18" Chain Saw. When I
Check to see if you have the chain oriented correctly - it is east to put them on backward without realizing it. Th3e teeth should point forward, with the anti - kickback lug in front of the tooth. Let me know if this helps!!
Nov 05, 2010 | Poulan Pro Chain Saw 46cc 20"
How do i tighten the chain on a stihl 038av magnum?
Normally, a loose chain will enhance it's ability to jump off when trimming small branches.
When installing and/or adjusting a chain;
1) install the chain, bar, and cover, and install the cover nut loosely
2) support the 'nose' end of the bar with a block
3) tighten the chain until it touches the bottom of the bar,
and then tighen the adjuster 1/8 of a turn more.
*this will make the chain just a LITTLE snug
4) tighten the cover nut, and then by hand CAREFULLY rotate the chain.
If you cannot rotate by hand, it is too tight. re-adjsut
** This proceedure must be used on ANY brand chain saw.
Here is why.
If the bar nose is not lifted upon adjustment, when cutting,
the nose will move upward, the chain will have a 'droop' away
from the bar and appear to have loosened while cutting.
Any contact with a small branch will flip the chain off of the bar.
If you re-adjust it improperly, the same senerio will occur the next cut.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 22, 2009 | Garden
Chain keeps coming off
Here is why.
Nov 12, 2009 | Remington Electric Chain Saw
Why does my chain come off all the time
could be one of several reasons ,you could be running the chain too loose ,the bar could be excessivly worn or the drive sprocket in behind the clutch ,that drives the chain could be worn out. all i can say for certain is that , it is one of ,or a combination of those things an ex perienced eye would pick it straight away on seeing it "youdoit"
Nov 09, 2009 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
Poulan PP4218AUX will not start
I have a 42 cc 14"bar will not start. poulan chain saw.
Feb 18, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
96 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
