Question about Keurig B70 Coffee Maker
My coffeemaker stops sucking in water and it shuts down even though it has full water in the resevoir.Sometimes in the middle of brewing a cup of coffee it will indicate not ready and stop or shut down.
  • 12 Answers
These brewers (especially B77, usually from Costco) are defective & Keurig is replacing them with new units @ no cost. Just call the toll free # (866-901-2739) & they will ship out a replacement in 3 to 10 business days. I own (2) of these & they have both been replaced. Even if not the above mentioned model, call them anyway & see what they will do for you......
Posted on Feb 15, 2010
    President:
  • 1,015 Answers
When you pull the water resevoir out verify that the small metal screen located in the water intake valve is not plugged with debris. You might also want to try running the de-scailing procedure using a cup of distilled vinegar in the resovoir with water. Then run two or three empty cups through to pull the vinegar into the unit and let it sit for about 30 minutes. Then run an entire resevoir of water back through to clear out the vinegar and scale.
Another possibility is that the float magnet in the resevoir might be sticking causing the Keurig to think that the resevoir is empty or not installed. There is a magnetic sensor at the side of the resevoir(inside keurig unit) and at the bottom(inside keurig unit). The sensor on the side detects the resovoir is installed and the sensor at the bottom detects when the water is low using the floating magnet. Make sure the floating magnet is not stuck and moves freely. If it is then there might be a problem with one of the sensors shorting out or a internal electrical problem. Anything beyond the floating magnet being the problem then you will need to contact Keurig if the unit is still under warranty.
Posted on Jan 30, 2010
Use a paper clip to clean the openings in the needle in the upper portion of the brewer head. There there are three openings around the outside of the needle.
Posted on Jun 11, 2011
I cannot get my coffeemaker to brew. Do i need to replace filter before it will brew, or clean with vinegar?
Run a couple cups of white vinegar through it (just like you were making coffee). Don't use a filter. You can use the same vinegar over again if necessary.
If calcium build-up is the problem, you will see lots of little flakes in the used vinegar. Continue running vinegar through it until you are sure the flakes have stopped, then run a couple full pots of water through it before you try making coffee.
Mar 10, 2015 | Coffeemaker Coffee Makers & Espresso...
Mini keurig stops brewing and blows tops off k-cups
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Jan 01, 2013 | Keurig Mini B31 Plus Black Coffee Maker
Won't make full pot
Okay, try this, make sure that everything is cool first, then take a turkey baster full of hot water and vinegar and shoot it backwards through the coffee maker...where the water falls on to the grinds. After that, try running either a commercial coffee pot cleaner or just again, vinegar through the brew cycle with no coffee in there. Try it two or three times, there may be calcium buildup in the filter and pump. You could also try that CLR cleaner, but make sure you rinse the pot out really good, and run a few cycles of just water before you drink anything from it.
Hope this makes sense and helps you out!
Jan 12, 2009 | GE Coffee Makers & Espresso Machines
Coffeemaker will not brew a full pot
Try cleaning it with pure vinegar. 3-4 times just keep running it through the machine.
Jan 12, 2009 | GE 106591 Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I have the same problem with the exact same coffee maker I have tried pushing the 1-4 cups button. That worked for a couple weeks, now it is back to only brewing half the water in reservoir whether I push the 1-4 button or not. It is very annoying.
Nov 14, 2008 | Cuisinart DCC-1200 Coffee Maker
Brews most of the water than stops and shuts itself off
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Aug 27, 2008 | Cuisinart DCC-1200 Coffee Maker
Keurig B70 Coffee Maker Logo
1,477 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
