Question about GE JSP26 Electric Kitchen Range
Surface unit control problem
The surface unit light won't go off and one burner stays on even though all the controls are on off
  • GE Master
  • 3,361 Answers
The burner element that is staying ON is also the same one causing the surface light to stay on.
The switch that controls the element is bad.
Unplug the range. Open the switch control console and replace the defective switch.
Make sure the range is unplugged because of high voltage in the console.
Posted on Jan 30, 2010
Testimonial: "Thanks very much!"
My surface light bulb burned out and I replaced it with a new bulb. But now the bulb stays lit and it won't turn off even though I turn it off from the light switch. Please help.
The only fix for it is to either buy another control board $300+ or if you are any good at wiring you can go the the hardware store get a manual toggle switch and install it under the microwave on the right hand side near the control area. But make sure the switch can handle the heat rising from the stove burners. We have about 120 of the microwaves on our properties and 6 of them have this issue. The relay internal switch becomes corroded and binds together from steam and boiling water. GE is JUNK.
Oct 30, 2011 | GE JVM1790 1000 Watts Convection /...
The light for the right back burner stays on,even though the burner is turned off and is cool
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on
heatman101
Dec 25, 2010 | Microwave Ovens
On indicator light on my Maytag touch control 500 electric smoothtop range will not turn off, even though all burners are turned off. I also shut the power off but the light still stays on
I can't help you with this if the light will not go off on one burner then replace that switch . but if you turn the power off and the light still is on. the unit is getting power from another unknowen source . mm
Jul 08, 2010 | Maytag MEC5430BDS Electric Cooktop
I have a GE stove that has a red light for HOT SURFACE
The control switch for the right front burner is bad. A new switch will solve the problem.
The situation,while annoying is not dangerous.
Feb 18, 2010 | GE Kitchen Ranges
Electric range surface light stays on
When the burner went, it took out the switch that controls it. The contacts inside the switch have welded together. That switch needs to be replaced. You should also look at the receptacle that the burner plus into. That may have been the original cause of all the problems. The contacts in them often wear causing the burner to src inside the receptacle. These parts should be readily available from Sears: burner control (infinie) switch, Burner receptacle.
Apr 09, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Hot Surface Light Stays On
you do have a top burner sensor that has failed. the hard thing is to figure out which one. most of these units have a 5 year part warranty, but you have to pay for an authorized servicer replace it for you.
if you want to figure it out yourself, you will have to find which of the wires, from the burner sensor, controls the indicator light. its not hard as it is usually the smaller one. each burner has a sensor and if you are certain you can work with the electricity on, its just a process of elimination.
unplug the unit from the wall, then take off the wire from 1 burner at a time, tape it off, to prevent shorting to ground, then plug back in and see if the light has gone out.
then you can order the new sensor, but on some models, you have to get the whole burner and sensor assembly.
Dec 28, 2008 | Maytag MER5775Q Electric Kitchen Range
Cooktop light stays on when cool
no your not doing anything wrong. the unit has a fault. you should call your nearest warrenty agent
Mar 08, 2008 | Kenmore 95002 / 95004 Electric Kitchen...
Surface unit indicator light is always on
Coffy, if you are talking about the hot surface indicator lights, they are controlled by the limiter on the burner itself. When the burner heats up the limiter closes and sends power to the light (hot surface). When the burner cools the limiter is supposed to open cutting power to the hot surface indicator light. They may be stuck closed. If you are talking about the lights on the back panel, that is controlled by the infinate switch itself. Catriver
Oct 09, 2007 | Kenmore 96012 / 96014 / 96019 Electric...
Burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
Oct 08, 2007 | GE Spectra JBP78 Electric Kitchen Range
GE JSP26 Electric Kitchen Range Logo
541 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
