Question about RCA P52936 52" Rear Projection Television
Sound but no picture. I'm thinking I need a new picture tube but how much is it going to cost me?
  • 5,081 Answers
First make sure to hit the menu button on the TV's remote and if nothing is there then friend while the set is on turn a bright flashlight on and shine at angle into the set push the TV menu button if you can see a image then your back light is not working.
You can also check the transformers they are close to were the wires plug into the panel, make sure all transformers read the same amount of resistance if not you have found a bad one. Now you will have to check to see if the power supply is sending 24v to the backlight, if not the power supply is bad. Cost backlights around 150.00 and power supplies around 100.00. Well this should help you friend.
Posted on Jan 30, 2010
  • 10,594 Answers
I disagree with given info that belongs to lcd tv whereas RCA P52936 is rear projection tv that has totally different things inside and real hands-on experience technician knows it.
Your tv has three picture tubes inside and I don't think all got failed at same time. Check horizontal deflection circuit and make sure its working, check screen volts of all three picture tubes.
Posted on Jul 29, 2010
It has sound but why did picture go black?
Probably your TV screen's picture tube has a problem. Get your picture tube checked.
Oct 09, 2015 | Samsung Televison & Video
RCA 27R411T 30" TV - purchased 2004
yes i think the tv is on its way out
could be in the jasks the main board
your picture tube could be on the way out also its most cheaper on you to purchase a new set
Jul 29, 2008 | RCA 27R411T 27" TV
I have a Sony Trinitro 36" about 8 yeras old. When I first turn it on, I can hear the sound but the picture goes in and out a few times before it stays on, now it is doing it every once in a while during...
Its a good bet that the picture tube is going bad. Thats the classic symptom of a failing tube. The tubes if available cost more than new tv's.. Sorry
Aug 11, 2010 | Sony Televison & Video
12 yr. old 25" G.E. picture fading
I gotta love it when people make up answers. There is no such thing as a "contrass module". I'm assuming the poster meant "contrast". The trouble is your 12-year-old picture tube. It's gotten weak and isn't getting as bright or sharp as it used to. Picture tube manufacturers estimate the useful life of a tube at about 7 years today. There are adjustments inside that might help some, but you need a new picture tube. It's going to cost a lot more than $60 to $75 for that. You're better off replacing the TV.
Apr 22, 2009 | GE 25GT240 25" TV
Blank screen on panasonic television
Hi, u have clearly mentioned that u are able to hear the sound from ur television. So the audio port of ur tv has no problem. The problem is that the picture tube of ur tv has damaged totally. Video output port has lost its ability to display on screen. If u are in a option of repairing ur tv its better to get a new picture tube or else if u opt for purchasing ur new television its well and good. but the cost for replacing ur new picture tube costs more.
Jan 26, 2009 | Panasonic Televison & Video
High pitched sound
The high-pitched squeal is from the power supply, usually because of failure of the horizontal output transistor, flyback transformer, or both. Without a specific model I can't give more definite information about part numbers or likely costs. But repairs of this type usually have parts costs in the 10 to 75 dollar range (depending on just which parts are bad, and where replacements come from) plus whatever labor costs the repairer charges.
Nov 13, 2008 | Televison & Video
No picture
unfortunately, your TV's tube has burned out. the replacement for a tube will probably cost close to the TV's price. At this point, your best option is to get a new TV.
Aug 29, 2008 | RCA F27664 27" TV
Picture is gone! :*(
the picture tube (what makes the TV picture work) has blown out. Just call you nearest tv reapair shop and purchase a new one. (these are kind of expensive!)
(Also, if it's fifteen years old, i think it's time to get a new T.V. hint. hint.)
Jul 03, 2008 | Zenith C27A24T 27" TV
Old tv's
I dont think you need a picture tube. If the audio still works when the picture goes out I would suggest checking the solder on the vertical output IC that could make the picture tubes blank out. Look for hairline cracks and resolder just to make sure. Let me know how you make out or if you need more info.
Mar 13, 2008 | Zenith R57W46 57" Rear Projection...
No picture or sound
The most common cause for a bowed picture is the convergence power supply module. The module will fail and sometimes blow the fuse. Average cost of repair would be around $100, if you brought it to a tv shop, more for in home service.
Sep 08, 2007 | RCA P46920BL 46" Rear Projection...
RCA P52936 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
