Question about Compaq Presario 5000 PC Desktop
My cd-roms work seperstely but not as a pair. The small 3-prong hookup wire is not connected to anything
  • May 11, 2010
    That small 3-prong cable doesn't need to connect anywhere. It's just an audio connector that most computers don't use anyway these days. What exactly is the trouble you're having? I don't understand what you mean that the CD drives aren't working as a pair. They are separate devices. Can you explain a little more?
    Scholar:
  • 59 Answers
By 'work' are you referring to loading software, being able to see the drive in windows and find/access files on the drive,... or are you referring only to playing cd music directly from the drive(s). Most likely the 3 conductor wire you are referring to is specifically for the audio playback of cd music directly from the drive to the sound card. In any case, the 3 conductor audio cable is not necessary for the drive to operate.
For the moment I will assume you are adding a new or at least second cd/dvd drive to your system:
If you can only use one at a time (not being able to see at least one drive in windows when both are connected, or not see any drive when both are connected) the master/slave settings are not correct on the drives. On each of the drives is a series of pinouts between the IDE connector and the power connector. Either in front of the pins or on a label on the top of the drives you will see MA, SL, CS or Master, Slave, Cable Select. If your IDE (Flat, wide cable with 1 conductor having a red stripe has the words Master and Slave stamped on it, you may use the shortout connector and set both drives to CS). If the cable is not labeled you may not be able to use Cable Select and have to set one drive to Master and the other to Slave. In either case,.. once you set the drives appropriately, and connect the cables correctly,.. both drives will show up in windows and be accessible.
I hope this helps you with the issue.
Posted on Feb 07, 2010
Changing power cord from 3 wire connection to 4 wire connection
Hi jdebesch
Go to the following webpage and the pictures will show you how to convert you or 3 wire to a 4 wire connection.
I believe this is what your looking for
Please take time to rate me
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Nov 25, 2012 | Hotpoint Dryers
How to ground a MDE6700AYW dryer after changing to a 3 prong cord
Hi fievelsgal21...
Go to the following webpage and it will show you what and where to connect the ground wire when converting from 3 to 4 wire or 4 to 3 wire.
Please rate me
Bud
Sep 28, 2012 | Maytag Neptune MDE6700A Electric Dryer
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
Can you tell me how to hookup the three wires of 3 prong cord to the back of dryer that came with 4 wires(4 prong)? Which one goes where? I only have 3 prong plugs at my house. Thank you.
The following link explains how to connect a power cord to your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Now keep in mind, some newer appliances REQUIRE a 4-prong plug in order to work properly. You may consider having a four-prong outlet installed to accomodate your dryer.
You can try these steps by referring to to section that discusses converting from a 4-prong to a 3-prong power cord.
If you have questions, please let me know. I hope this helps you.
Jul 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I HAVE A DISC JAMMED INSIDE WON'T OPEN OR PLAY HELP.....
check out internal wiring connection of CD ROM.the loose connection may create problem.
if connections are proper then check whether ur CD ROM working properly or not by connecting to another cpu.
i hv one master soln on it.but u hv to do it very carefully. 1st start pc then take a sharp thin stick & push it softly in lower small space of CD ROM & pull out it gently.
but it only possible if u put the cd properly in CD ROM.
so try it ,it defntly works.
dont forget to feedback me.
Jul 04, 2009 | Sony Playstation 3 (PS3) Console
Roper Dryer
Mar 02, 2009 | Roper Dryers
4 prong to 3 prong
connect green wire back to cabinet rear at green screw..in a 4 wire hookup the green wire from the dryer was supposed to be either cut off or attached back to neutral(center screw)
Oct 24, 2008 | Roper REX4634KQ Electric Dryer
Compaq Presario 5000 PC Desktop Logo
23 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
