Question about Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker
What size amp do i use with 2 1100 watt 10" sony subwoofers
  • Davis M May 11, 2010
    What are you trying to accomplish with these things? I've got a single 300W amp hooked to my sony p5(12" actually) and it can put out enough bass to get my feeling sick after a while... and at best I'm only turned up half way on the amp. I'd think a 600W amp could keep you happy unless you're trying to compete with the system on the next block over :P Oh, and the 300w & 600w amps I have in mind are an older variety of Jensen(black and silver color scheme), if that puts things into perspective.
    Sergeant:
  • 279 Answers
I have the same set of speakers and im running a kenwood 2 channel amplifier thats bridged and it works well.
Posted on Jan 30, 2010
  • roger Jan 30, 2010
    1000 watt amplifier
3 Suggested Answers
  • 74 Answers
SOURCE: need an amp to go with speakers
you could get a 1100 watt amp, but, it is ALWAYS good to get a smaller amp than the max rating so you have a "safe" zone and turn it up all the way so you don't have to worry about always running it at its peak( which sounds better but more chance of blowing it)
Posted on Feb 18, 2009
  • 13 Answers
SOURCE: What size is the voice coil in my 1100w 10" sony xplod sub?
go to the sony website or any dealer website and look at the model number of your sub, punch that in and get the measurement.. mostly gonna be inches.. but then go to google and convert it to mm
Posted on Apr 08, 2009
How do I connect a Sony xplod 1000 watt 2 channel amp to 1 10" dual 4 ohm voice coil 1500 watt planet audio subwoofer?
Connect one voice coil to one channel of the amp. Repeat with the other voice coil. Do not bridge the amp as your only choices would be series which would be an 8 ohm final load and cuts the amp power in half or parallel wiring which results in a 2 ohm load and very few Sony amps currently made can handle being bridged to a 2 ohm load.
Aug 28, 2016 | Sony Car Audio & Video
Are sony xplod 1100 watt 10'' subs 2 ohm stable
No keep on trying end blow everry thing up, Buy some real subs.
Nov 29, 2012 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
What watt amp would be best for my 1100 watt 10 inch xplod?
I have a 1100 watt sony xplode the silver one 4 ohm rms 3 00 with a 3000 watt 400 rms pyle amp? 8 ohm
Sep 16, 2011 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Car audio
If you are asking if you can have a kenwood amp hooked up to your Sony Head unit then yes it would be compatable.
Jun 02, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I have 2 10' sony xplodes connected to a 2
If your radio is still playing and the subs are giving you music, you most likely have the amp remote wire hooked to a constant power source on the radio. Generally, this is a solid blue wire on both the radio and the wiring harness. It allows the radio to turn the amp on and off when the radio is on or, subsequently, off.
Apr 21, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
What wattage amp do I need to get good sound in a toyota corolla
Make sure it's a RMS 1200 wats not MAX watts also the Ohms of this speakers and them you can buy any amp. with the same RMS watts of your speaker and same Ohms of resistance.
Jan 27, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Apr 06, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Need an amp to go with speakers
Feb 18, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Amp
you could use a 2000 what amp
Dec 06, 2008 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker Logo
1,113 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
