Question about Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome...
I am reinstalling a Moen 7345 riser faucet in my laundry room. This faucet was removed from a bar sink two years ago by the contractor who replaced my kitchen counters and changed my two kitchen sink faucets. I went to install the hose to the riser stem and the hose seems to not be seated against anything allowing the hose to be loose in the connector. It seems to me like there should be a solid washer or something for the hose washer to seal against. I have put it together just like I took it apart from how the contractor left it for me. It seems like maybe a part is missing. I have ordered a new hose assembly from Moen hoping that it includes whatever I may be missing. It does leak around the hose when the water is turned on.
I had a similar problem and, like you, found that there was nothing for the washer to seat against. Apparently, there was a metal bushing installed when manufactured, that was entirely eaten away by electrolytic corrosion - mine took nearly twenty years. I machined a new non-metallic bushing, installed it, and the problem was solved.
I also sent Moen's president a letter explaining the problem and how to fix it but heard nothing back from them. At the time, no parts were offered that could fix the problem.
Posted on Mar 23, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    I need replacement part for bath sink cartridge 4570
    The Moen 1225 or 1200 cartridges are the same except the 1200 is brass in stead of plastic. They will fit most Moen single handle faucets. If it is a two-handle faucet, the 1224 cartridge will fit most two-handle models unless it is a fancy widespread faucet more than about 15 years old. I don't know the model numbers for those cartridges. All of these cartridges require a removal tool if you can't get them out with a pair of pliers.
    Dec 09, 2011 | Moen Soap & Lotion Dispenser 3910S
    I have a 15 year old Moen bathfaucet 4650-P that I want to replace. I can't figure out how to remove this old faucet. It has three holes with the outer holes on 4 inch spacing. The two handles and the...
    There is definitly a nut or nuts holding the faucet to the sink. It could be around the center shaft that goes through the sink, but most likely 2 small nuts that screw onto the 2 outer stubs. These are your hot and cold wated supplies. crawl underneath the cabinets and check. It might be difficult to get them off, but they do make a pipe wrench tool that has a rotating head that makes this easier
    Mar 04, 2011 | Moen Home
    My classmate
    Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
    Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Moen L3175 faucet with low water pressure
    IS THIS A SHOWER ONLY? IF SO ,I WOULD REMOVE THE SHOWER HEAD FIRST THEN TURN YOUR WATER ON.THE HEAD JUST MIGHT NEED TO BE CLEANED AFTER 11 YEARS.
    May 10, 2010 | Moen L3175 Chrome Legend Single Handle...
    Moen faucet removal
    you will have two mounting nuts at each end and two water line to disconnect for removal under the sink on any faucet made
    Feb 13, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    We are trying to replace our Moen Adler Faucet and we need to know how to remove it.
    first off swhut the water off under the sink,if no shut off valves under the sink then shut the main water valve off.next turn the old faucet on to make sure water is off.now get a light and look up and behind the underneath side of sink,disconnect the water supply lines now way up high there is 2 threaded tubes undo the nuts and the old unit will come out.
    Jan 11, 2010 | Porter Cable Moen Legend, Single-Handle...
    HOW TO DISMENTLE OR REPLACE A MOEN SINGLE LEVER
    shut water off at stops under sink. Unscrew water supply lines from directly below handles. Above them you will find plastic nuts, remove them. Disconnect pop/up lever and you should be able to lift faucet from sink.
    Sep 24, 2009 | Moen & One Handle Tub & Shower Faucet
    Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
    830 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
