Question about Proscan 32LA25Q 32 in. LCD TV
Picture blacks out but audio is still on.
The picture on the tube will black on, but the audio is still on. As if it goes on standby like a computer. At times, it won't turn on unless you use the button on the tv itself.
i
  • 732 Answers
Immirella, If you don't have extended warranty you will need to repair it yourself or contract out the work. This seems like (from your description
) that one or more of the units DC voltage sources on the "switch-mode-power-supply has failed and is now in partial shutdown mode. Yes, the unit still has operating voltage source for the digital, tuner, and audio circuits. You may or may not see an image on the screen if you hear audio and shine a very bright flashlight 1 inch from the lcd panel. You should pay a visit to YOUTUBE (just FYI) to check-out repair video clips of LCD monitors and LCD tv's. Your unit (FYI) is classed as BLACK SCREEN of DEATH. Same as any other brand of LCD monitor or tv. Call a local repair tech for more info. Good luck. 12fixlouie
Posted on Jan 30, 2010
Standby light
This problems is cause by FBT-Flyback tranformer the big black block of plastic with a red wire with a cap hook to the CRT(tv tube) and the "H" horizonal transistor left side of the steal plate cage of the big black block of FBT.U have soldering tool,and solders?Resolders the FBT,and "H" horizontal transistor will help to stop this problems,if those parts are still goods,not dying.Or might help just leave the tv on 4 or 5 hours,the heat of the tv could heal the cold solders itself.
May 10, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony Rear Projection TV - KP-46WT500 Screen went blank
When Sony TV gets problem it goes to standby as protection mode and LED start flashing.
Do you see standby light blinking?
There would be 3 seconds interval between blinks so count from pause to pause and let me know.
Thanks.
Sep 20, 2009 | Sony KP-46WT500 46" Rear Projection...
Kp-fs57 blue screen then turns off
Could be one of three things the yokes, the flyback transformer or the picture tubes, all will be a costly repair. If it was mine I would invest the money in a new one.
Sep 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Was watching tv all of sudden screen turned black, with audio...
i was watcing tv afeter a while i realized there is no picture but we have sound
Jul 14, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Jan 12, 2009 | RCA 15L500TD 15 in. TV/DVD Combo
Video goes black on startup
sems like your pisture tube for the tv is going slowly out. replace the tube or replace the tv, its cheaper to replace the tv then a new tv screen colour tube.
Aug 23, 2008 | Sharp Aquos LC-32D40U Television
Standby
I think your picture tube is weak.
You can verify this by taking the back off and slowly adjust the the screen control (it is mounted on the flyback transformer) the one with the wire coming out the top and going to the picture tube
the lower one. it is black and serrated and less than 1/4" in diameter.
turn counter clockwise first then advance it while someone watches for the picture.
If it comes on you know the tube is weak.
it may last for a while at that setting, but be prepared to buy a new set.
Thanks Guy9
Jun 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Old tv's
I dont think you need a picture tube. If the audio still works when the picture goes out I would suggest checking the solder on the vertical output IC that could make the picture tubes blank out. Look for hairline cracks and resolder just to make sure. Let me know how you make out or if you need more info.
Mar 13, 2008 | Zenith R57W46 57" Rear Projection...
Sony KP-57HW40 57 in
Bad blue CRT ...........common problem...........T.
Nov 10, 2007 | Sony KP-57HW40 57" Rear Projection...
Picture goes to black
tube is shorting out needs a new tube
Nov 09, 2007 | Televison & Video
Proscan 32LA25Q 32 in. LCD TV Logo
406 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
