Question about Sport & Outdoor - Others
Punctured inner bladder Tachikara SV-5 volleyball
The inner bladder of my tachikara SV-5 volleyball has a puncture ... how can i repair it?
Fix A Flat. Screw the needle valve into the noozle of a can of Fix a Flat. Squirt enough in to inflate to normal pressure, Roll the ball around to coat the inside. Blow the needle valve clear afterwards attached to a bike pump.
Posted on Mar 30, 2010
How wide are the lines on a volleyball court?
The regulation width of a volleyball court line is 5 centimeters. This goes for all the lines on the court.
Jan 14, 2013 | Volleyball
Took inner bladder out now won't hold water
Inner bladder is needed to hold the fresh water for spray. Make sure the bladder is pulled through the bottom of the tank and that the black cap with a red rubber seal on the bottom of the tank.
If the black cap is missing you'll need to purchase a new one. Here's a quick link.
http://www.bissell.com/parts/?id=9143&sc=product&productid=2813&cid=ccsocial
Here's a quick link to locating a BISSELL Authorized Service Center if you need more assistance.
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 13, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
Can you repair sevylor bladders? if so how?
dollar store contact cement in tube., an old bike tire, cut a patch out of tire and glue the patch on glueing around hole and underneath patch. apply patch smoothly. now glue around edge of patch. and let it dry for a few days at least 24 hrs. I have patched a bic yakka and a few cheaper inflatables patches hold up and hold air. good luck.
Aug 30, 2012 | Stearns SEVYLOR Sit on Top Kayak U250
The procedure for removing the rear wheel from my Trek Navigator 200 to repair a puncture or replace the inner tube. Regards Paul emson
Try any Search Engine for "removing the rear wheel " and "repair a puncture"
The internet has most answers immediately and some with video.
Aug 08, 2011 | Trek Navigator 200
How do i fill the water
There is a tank within a tank design on these deep cleaners. Use warm tap water and fill the inner bladder.
The Tank-in-Tank system is designed with a bladder inside for
clean water. As you clean, the bladder will empty. Dirty water
collects in the tank outside the bladder.
Apr 20, 2011 | Bissell 8910 ProHeat Clear View Upright...
I have the quinny buzz and have a problem with one of the rear wheels. It appears to have 5 holes in it (around the inner part that attaches to the plastic centre part, they are very small holes and I had...
hi this is a very easy fix have you searched the web for quinny buzz inner tubes? ebat has loads if you are in the uk
or it is a 12 inch bent valve inner tube my advice is when you have repaired these put in tyre slime
this will help any future punctures by repairing them immediatley and you wont even know
very good stuff had it in mine and never had to pump them up good for any inflatable tyres with an
inner tube
Nov 16, 2010 | Quinny Buzz Three Wheel Stroller
Back wheels keep deflating
hi, the chances are you have a puncture os something sharp sticking into the inner tube inside the tyre, what you need to do is buy a puncture repair kit then using the repair kit you take the tyre off the wheel then take the inner tube out.
now blow the inner tube up and place it in bowl of water and you should see bubbles coming off the inner tube, mark this with pen when dry so you know where the whole is, now use the puncture kit and place a patch over the whole, you can buy glue type patches or stick on patches without glue, you peel the back off the patch and put glue on or stick it over the whole if its a stick on patch and not glue.
then whilst this dry run your fingers around the inside of the tyre and check for any thorns or something sharp sticking in the tyre if you feel anything remove it and you should be ok, then when glue dry put the inner tube back in tyre and fit the tyre back on wheel now when you pump it up it shouldnt go back down unless you get another puncture.
if you are unsure what you are doing then taking your stroller into any bike shop and ask them to repair the punctures for you and they will do this for you whilst you wait.
Jul 10, 2010 | Quinny Buzz Three Wheel Stroller
How do you fix a flat tyre on a maxi cosi mura?
If you have a puncture and there is only one hole, you can get a puncture repair kit for bikes from somewhere like Halfords and repair the inner tube.
I found the inner tube on one of our tyres was faulty and there were about 20 small holes around the seam. I got a bit fed up with arguing whether or not the guarantee should cover this and so we ended up buying a new inner tube from our local tyre place http://www.etbtyres.co.uk/ it was only £5.
Sep 28, 2009 | Maxi-Cosi Baby Gear
Help- wheel problem!
Call or email the company. I had the same problem and they sent me a new inner tube for free b/c my stroller was still under warranty (yours should be too). I took the new tube and the stroller to a bike shop where they finished the repair for me for $5.
Oct 06, 2006 | Bugaboo Cameleon Jogger
Sport & Outdoor - Others Logo
837 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
