Question about LG WM-1485FHD Front Load Washer
Soap dispenser not working
Model wm2277hs:
I loved my washer up until a week ago. First thing I noticed was that water would be left over in my soap dispenser drawer and I would have to empty it before the next load. No problem just a few extra steps. Then all of a sudden none of the soap, fabric softner etc. would wash out into the wash. I called the service center they informed me about the drain at the bottom left which I never knew about. Emptied that and have run a cycle with no soap and no spin as suggested. Did not work! I have done this three more times to no avail. I even removed the soap dispenser tray and ran hot water through out the hose to rinse it out. Did not work. Have NEVER used anything but he tide in my machine. When I did run the cleaning cycle there was a little water left in the dispenser tray so the water seems to be running through when there is no soap in it. PLEASE HELP!
  • Anonymous May 09, 2008
    soap dispencer over flows with water.. will not drain in to tub
    clogged with powder detergent
  • 489 Answers
It sounds like the water valve has a clogged filter.  Shut the cold water to the washer off, disconnect the hose and remove the filter screen in the washer water valve.  Clean out the filter with toothbrush.  Reinstall and everything should be ok.
Posted on Apr 28, 2008
2 Suggested Answers
SOURCE: My front load washer will not empty out the fabric
I have the same problem with mine. I found that some fabric softners worked better than others. I found Downy the worst, when i switched the problem seems to stop once i cleaned out the drawer
Posted on Dec 01, 2009
Why does my Electrolux #EWFLW65HIW have water left in soap dispenser
Good Afternoon Friend,
I understand that your Electrolux washer, model# EWFLW65HIW, has water left in the soap dispenser. This is typical for your particular model. The soap and fabric softener area are set up on what is called a siphoning system. This means that when it is time for the soap to release it will release and run water through the area. If the mechanism closes before the water is done running through, you can have water left in the soap dispenser. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Electrolux Washing Machines
No high pressure water
I have a SIMONIZ S2000 electric. I bought the unit about 8 weeks ago used it once. On the second use yesterday the unit didn't work as well, the pressure seemed only a bit better than hose pressure and soap did not dispense at any pressure. SO.... after much thought I turned the hose/tap pressure down so that I only got about 2-3 GPM instead of the typical 5-6GPM normally coming out of my hose....... it worked! Soap dispenses and spay is way better! It seems that if if the inlet hose pressure is high the pump doesn't work as well... go figure.
Jul 01, 2010 | Karcher 1550PSI Pressure Washer
BOSCH DISHWASHER SHU43C06UC/17 NO WATER UPPER ARM
Ours is a SHU3300UC/06 model, basic model which we bought in 1999 so have had 9 years of trouble free service.
Recently we noticed that there was soap left in the soap dispenser after the machine had finished all the cycles. On further inspection we noticed that the upper level glasses, cups and bowels are not consistently clean and it appears that the upper washing arm is not working properly. At the back of the upper washer arm, there is a rectangular piece that slides over the two water outlet tubes projecting out of the back of the washer which supply H20 to the upper arm. On removing the upper arm and the rectangular connector, I noticed there is an inner place that I think is supposed to work like a washer that fits tightly over the 2 water outlet tubes in the protruding from the back of the washer. I noted that the upper opening in the washer/seal is broken so a proper seal is not established. This would cause insufficient water pressure getting to the upper arm and reduce its effectiveness. Now I'm trying to find the replacement part. It appears to be something than can easily be replaced.
Dec 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
Apr 08, 2008 | LG WM-1485FHD Front Load Washer
Where's the soap going?
Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water in soap holder after washing.
my washer is about 1 year old. It started leaving water in all the the compartments,soap,bleach and softner. I tried everything also. Nothing seemed to work. I finally took the hoses off the back of the machine, and the cold water hose screen was clogged up going into the machine. I cleaned all the screens and haven't had that problem again. I think there wasn't enough water pressure to flush out the containers. I dont think its gravity or suction, its water pressure. unless you get a blast of water into these compartments, there will always be water left in these containers.
Oct 27, 2007 | LG WM-2277HW Front Load Washer
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Water in detergent dispenser
Remove dispencer again, remove conditioner syphon assembly and clean up the little tube. Should then go okay
Jul 06, 2007 | LG WM2277H Front Load Washer
LG WM-1485FHD Front Load Washer Logo
1,805 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
