Question about Jacuzzi RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,
Do you have to run a seperate circuit for a jucuzzi inline heater?
    Problem Solver:
  • 16 Answers
FOR MOST OF YOUR SPAS YOU SHOULD HAVE A OUTSIDE EMERGENCY SHUTOFF BOX NO CLOSER THEN 5 FEET FROM THE WATER LINE(YOU SHOULD NOT BE ABLE TO SIT IN THE SPA AN BE ABLE TO REACH OUT AN TOUCH THE EMERGENCY SHUTOFF) AN NO MORE THEN 100 FT AWAY FROM THE SPA. IT ALSO DEPENDS ON WHAT BRAND AN WHAT VOLTAGE YOU WILL BE SETTING IT UP AT MOST OF YOUR SPAS TODAY R CONVRTBLE FRM 110 TO 240V. MOST 110 ARE EASY SHOULD JUST BE A GFCI PROTECTED PLUG THAT YOU WOULD HAVE TO PLUG IN(ALWAYS SMART IF ITS A PLUG IN, YOU RUN A SEPERATE BREAKER AN LINE OUT TO A ALL WHEATHER RECPT. TO PLUG THE SPA INTO) THE PLUG COMING FROM THE SPA SHOULD BE A GFCI PROTECTED PLUG LIKE YOU WOULD SEE ON MOST HAIR DRYERS. 240V ALSO DEPENDING ON WHAT TYPE A SPA U NEED THAT EMERGENCY GFCI PROTECTED BOX OUTSIDE(MOST GOOD DEALERS WILL OFFER YOU THIS BOX WHEN YOU BUY THE SPA) BEACUSE ALL BRANDS WILL BE HARDWIRED IN A DIFFERENT WAY SOME REQUIRE A DOUBLE POLE GFCI 30AMP BREAKER FOR JUST THE HEATER AN A SINGAL POLE GFCI 20AMP FOR THE PUMPS ALWAYS WANT THE GFCI OUT AT THE SPAS OUTSIDE SHUTOFF BOX INSTEAD OF IN THE MAIN BREAKER BOX BUT LIKE ALWAYS REFER TO THE MANUEL AN HIRE A ELECTRICIAN WHO HAS DONE SPAS B/4.
Posted on Mar 27, 2010
HAVE AN OLD MODEL #45-552701 ON DEMAND HEATER NEED TO KNOW HOW TO HOOK IT UP IN CABIN
in general, it requires power and water.
power and fusing is relative to KW rating of unit
install seperate circuit in fuse panel
run appropriate size wire to location
connect cold in and hot out water lines
connect power, run water to bleed air.
turn on breaker sw.
Dec 09, 2014 | Water Heaters
Jucuzzi Model U670 Espree 636 does not turn off after running. Have there been similar probelms reported and if it is the switch, can the switch be removed from the top?
Yes, I replaced mine from the top. It's fairly easy. You have to pop it out after you get the trim off carefully and then pull the air switch out remembering to get the 1/4 house to come out with the air switch so you can detach it and connect the new one.
Aug 06, 2012 | Jacuzzi Home
I have a Kenmore Microwave Hood 721.63653300. I unscrewed one of the light bulbs and the glassw seperated from the base which cased a small pop now the unit will not run. I have check the power to the unit...
All Microwave ovens have a main fuse that is not accessible while the unit is mounted under a cabinet. Drop MW oven and replace the main fuse.
Dec 23, 2017 | Microwave Ovens
Inside temp set at 32.00 but after the auxiliary heater has been on for the 30 mins it is blowing cold according to the book it runs at top temp
Hi your car is fitted with a seperate auxillary water pump for the heater circuit it may have stopped working idealy you need to get it checked on a dealer diagnostic test computer as it will pick up
heater faults and check the electrical circuits to the webasto heater under the bonnet
Dec 19, 2010 | 2005 BMW X5
I need a picture diagram of how to wire up two different baseboard heaters with seperate thermoststs on the same wire in the breaker box.Never done this before and I don't want to burn down my home.
it can not be done. if you want 2 seperate thermastats servicing 2 seperate baseboards, then what you will have is 2 seperate circuits, one for each thermastat and baseboard. If you are talking about only at the breaker box, then that can be done.... assuming that the total amperage does not exceed the wire rating or the breaker..... if that is the case you will have to install a junction box and split the wiring BEFORE it goes to each seperate heating unit.
Mar 02, 2009 | Fahrenheat Electric Convector Baseboard...
I have an older jucuzzi spa. Model number z140. I had one of the primary wires burn through some time ago. I repaired this and the spa ran fine until yesterday. It quit running, heating, just plain quit. I...
I have found that most wires that overheat were caused by a loose connection. Wheather is was at the terminal screw or a bad solder joint on the circuit board. When there is enough heat to "bake" a wire, it most likely damaged the board as well. Check the traces on the back of the circuit board.
When you have a connection that is loose and "making & breaking" you are most likely to find carbon build up on the wire/ connector itself and it needs to be cleaned if not replaced.
Or keep it simple & replace the circuit board. Good luck
Jan 10, 2009 | Pool & Spa
Heater unit kicks out GFI
most require a seperate circuit for the heater. depending on HP on the circulation pump and wattage on heater.
Nov 30, 2008 | Home
Electric dryer
Most dryers have two fuses in them, one inline with the heater element and another thermal fuse in the main circuit. The one inline with the heater element can blow and the dryer will still run, but will not heat. If the dryer gets too hot it may blow the thermal fuse and kill power to the entire system.
Depending on your level of handiness, you may take the cover off (make sure the unit is unplugged from power) and look for a blown fuse. Most dryers have a schematic for repair somewhere on the unit, usually in the top control area.
KP
May 14, 2008 | Dryers
Jacuzzi RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools, Logo
401 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
