Question about Maytag Washing Machines
Model# LAT 8608 AAW Serial# A4105658 FY Maching stopped in spin cycle because of misbalance. We opened lid and rebalanced load, spin cycle would not restart. Water would refill for rinse, but spin cycle would not engage. Have tried to stop start at multiple other locations on the dial, but with no luck.
SOURCE: Maytag Washer Problem
Have you tried starting the wash cycle at several different time settings? Especially the shortest time setting, just before the start of the first spin? If it works at another setting, it's possible the dial/switch mechanism is worn and not making contact at your usual setting. In any case, a spray of a good electrical contact cleaner spray (NOT WD40 or similar) - with the power lead UNPLUGGED - sprayed into the switch mechanism might help. You would need to remove an access panel to get at the switch mechanism.
Ian from Australia
Posted on Dec 26, 2007
SOURCE: Whirlpool Model LSV6234AWO
door switch bad?
Posted on Oct 18, 2008
  • 50 Answers
SOURCE: Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Posted on Feb 26, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 212 Answers
SOURCE: Our washing maching stops running
lid switch is bad. replace switch
Posted on Jun 20, 2009
Whirlpool Cabrio spins off center and stop with ul code
Ul-Unbalanced Load
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the load.
If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute
the load.
May 28, 2012 | Whirlpool Washing Machines
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
Oct 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio washer is blinking uL HELP!
Hi. uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalanced the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load.
Aug 25, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
How do i fix UL load will not spin.
flash until the lid is opened, allowing the
CHECK TO MAKE SURE IT IS LEVEL. LET ME KNOW IF I CAN ASSSIST YOU FUTHER. YOU MAY HAVE A BAD CONTROL BOARD.
Apr 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My new Whirlpool Cabrio stops repeatedly with the UL flashing it never finishes a wash load, do you have a step by step CD explaining the use of this washer? I am about to return it to the store and get a...
I believe this model has a defective control board under the control panel. The new control board has longer times between the drain and the spin. Eliminating the unbalance when it tries to spin with water still left in it. Also check for slow drain this will enhance the problem. The control board is a warrany repair if covered.
Mar 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ian from Australia
Dec 26, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 70 Series Washer
You probably have a bad lid switch.
May 21, 2007 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
59 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
