Question about EliteGroup P4VMM2 Motherboard
Can you run ddr 400 on this motherboard - EliteGroup P4VMM2 Motherboard
  • 415 Answers
Yes, this motherboard can run DDR memory up to 400MHz. It accepts up to 2GB RAM.
Posted on Jan 30, 2010
DDR-400/PC-3200
if the memory supports those frequencies, in most cases it would work, now depending if the board is proprietary, like dell or some hp's, then you may run into compatibility issues. you can find this information from the manufactures website.
Oct 16, 2013 | Computers & Internet
What is the max ram Ican run with a 865pe neo2-p motherboard and
Main Memory
�� Supports bandwidth up to 3.2 GB/s (DDR 400) for single-channel mode and 6.
4GB/s (DDR 400) for dual-channel mode (for 865PE only).
�� Supports two (for 848P) / three (for 865PE) unbuffered DIMM of 2.5 Volt DDR
SDRAM
�� Supports up to 2GB (for 848P) / 3GB (for 865PE) memory size without ECC.
�� Supports only x8, x16 DDR devices.
�� Supports Dual-channel (for 865PE only) DDR 266/333/400 (based on DIMM 1.3).
(For the updated supporting memory modules, please visit http://www.msi.com.tw/
program/products/mainboard/mbd/pro_mbd_trp_list.php.)
Regards.
Apr 04, 2010 | MSI 865PE Neo2-V Motherboard
Can a ddr pc2700 replace ddr 400 pc3200 are they compatible? I only get beeps when booted
Yes it can be compatible.PC3200 DDR 400 will underclock down to PC2700 in order to match the frequency of the lower end memory card. In order for your system to run it should have a matched memory frequencies. But memory compatibility depends sometimes to its brand name.
I hope this could help you..Thanks..:-)
Dec 23, 2009 | Asrock P4VM890 Motherboard
How mutch RAM does "Motherboard MSI PM8M3-V (MS-7211 v1.x) Micro-ATX" supports
Spec sheet shows you can run 2GB of PC2700 DDR RAM (DDR-333), or PC3200 DDR RAM (DDR-400); http://www.superwarehouse.com/MSI_PM8M3-V_Micro_ATX_Pentium_4_Motherboard/PM8M3-V/ps/727805
MSI also provides a list of tested memory for the board;
http://www.msi.com/uploads/test_report/TR10_234.pdf
Hope you find this helpful!
Mike
Oct 12, 2009 | MSI PM8M3-V Motherboard
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
Memory upgrade, download upgrade to run 400
According to the specs of this motherboard, it only supports 333, 266 and 200 MHz DDR SDRAM. It does not support 400 MHz DDR SDRAM.
This motherboard has only 2 memory slots, each can accommodate a 1 GB memory module. Higher capacity memory modules are not supported by this motherboard.
No BIOS upgrade is available to provide support for 400 MHz DDR SDRAM memory modules.
Jun 04, 2009 | Intel D845GVSR Motherboard
RAM Help!
Hi there.
Yes it is related to PC2 and it runs at 800Mhz, this why your system is seeing only half the speed, your system does however support a module running at 333 module and a 400 module, this is the base limit that the memory runs at.
If the memory was 533 then the computer would not start up because the bios wouldn't recognize it.
Thanks for using FixYa!!
Apr 22, 2009 | EliteGroup P4M800-M7 Motherboard
Gigabyte GA-8IGX Motherboard memory upgrade
If you bay DDR 400 it will slow itself down to 266 automatically. I've seen a very few cases where it didn't work because of voltage differences but that is very rare and usually with really cheap OEM motherboards, your Gigabyte should be safe.
Aug 11, 2008 | Gigabyte GA-8IGX Motherboard
Memory Modules
Short answer is no. You can not run PC3200 DDR 400MHz memory. The fastest memory the motherboard can run in the,
(Biostar M7VIG 400) is PC2700 DDR 333MHz.
If you do not have you're manual, you can download it by clicking on this link: ftp://ftp.biostar-usa.com/manuals/M7VIG%20400/M7VIG400manual.pdf
Biostar M7VIG 400 main web site, click this link:
http://www.biostar-usa.com/mbdetails.asp?model=M7VIG+400
Good Luck!
Mike
Jun 18, 2008 | Biostar Mainboard M7VIGD-A02 VER:6.0...
EliteGroup P4VMM2 Motherboard Logo
98 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
