Question about Samsung SIR-S4040R DirecTV DTV Receiver / 35-Hours Video Recorder
Export via USB to hard drive
How do I export my programs out through USB to my hard drive? My macbook pro does not recognize the Samsung SIR when it is plugged in via USB cable. Thanks!
  • Kevinj851 Jun 17, 2008
    how can i export to a usb device
  • 3 Answers
The USB ports on this unit are non-functional unless you hack it. There are several methods of doing so, but the easiest is probably to purchase an upgrade kit from dvrupgrade.com. You can either purchase a replacement hard drive, or software to do it yourself.
After you do this, the USB ports can be used to connect a network device, and you can use different software programs to export and import programming. You will also have other features you normally wouldn't have on the stock unit. Good resources on this topic are tivocommunity.com and dealdatabase.com.
Posted on Jul 18, 2008
My Toshiba 250gb external hard drive model hddr250e03x is not recognized by my macbook pro but the light turns on. It works on my friend's macbook pro but not mine
I'm assuming you mean it doesn't appear in Finder. Open up disk utility and it should appear there if you say the MacBook is providing power to the hard drive light. You may have to reformat or reset your Mac if you want it in finder
I’m happy to help further over the phone at https://www.6ya.com/expert/tarik_f88885a87e319a0d
Oct 14, 2013 | Toshiba Canvio 500 GB USB 3.0 Portable...
My macbook pro doesnt recognize my toshiba canvio 3.0 external hard drive
When have you bought you mbp ?
Your External HDD is in which format, Do you have an app like NTFS for mac osx, or Tuxera NTFS on your MBP if your HDD is not formated as MAC OSX drive. .....
Nov 30, 2012 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My Kodak EasyShare won't export to my MacBook or the MacBook isn't recognizing the camera. It has worked many times in the past. Help!
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Jan 02, 2011 | Kodak EasyShare V1003 Digital Camera
Wiselink won't recognize my WD external hard drive
Your drive is setup as ntfs it needs to be formatted to fat32 via Windows and if Windows won't let you format it to fat32 you need to use a drive partitioner program you can find several free ones on the webz
Jun 06, 2010 | Samsung DLP HL-P5663W 56" TV
I am using SuperDuper to clone my 160GB MacBook Hard Drive to a 500GB Western Digital Scorpio Blue. My problem is that I cannot determine why neither the SuperDuper program nor the MacBook itself...
The Western Digital Scorpio Blue 500GB hard drive is formatted for PC, not Mac. The simplest way to get your MacBook to recognize this new drive--and therefore copy the files from your old drive--is to plug it in to a PC and format the drive. I was advised to format with FAT 16, as this would be recognized by my MacBook. Fortunately, the process was not that involved, since the Vista-driven PC found the drivers for the WD Scorpio Blue automatically. Once formatted, I safely removed the drive and plugged it into my MacBook via a USB port using a BYTECC Drive Mate. Magically, it now appeared on my MacBook Desktop and was recognized by the cloning software I was using, SuperDuper. Three hours later, the files on my old hard drive were successfully cloned onto the Scorpio Blue--except now I had an additional 364GB of storage space. Swapping out the old drive and replacing it with the new was not a big deal at all--just make sure you have the right screwdriver for the last task--a Torx #6. Mission accomplished.
Oct 24, 2009 | Western Digital Elements powered by WD 320...
Hard Drive not mounting
Check the jumper on each hard-drive.
My guess is that the WD drive has the jumper in the "correct" position, for mounting inside an external case, while the other drives have their jumper set to an "incorrect" position.
Set the jumper to MA(ster), not to SL(ave), nor to C(able)S(elect).
Sep 08, 2009 | Macally 1 Bay PHR-250CC (0701107485355)...
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
WD 500GB external hard drive won't load on new macbook
Dear Sir,kindly note this problem usually caused by a firmware damage,so you need find a dr company to use tool to repair the firmware,you can contact with me :honglake@gmail.com
Mar 19, 2009 | Western Digital 500GB My Book Pro-External...
My macbook pro does not recognized freeagent 1 TB. It sucks!!!!
You could contact Freeagent technical support at their website.
Jan 08, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Samsung SIR-S4040R DirecTV DTV Receiver / 35-Hours Video Recorder Logo
525 people viewed this question
Jerry Greenberg
Jerry Greenberg
