Running Windows 7. A windows Critical Update auto installed on Thursday and system ran fine for several hours. Then it hung and I had to re-boot. It would not reboot, not even into Safe Mode. It would hang after loading classpnp.sys. Now the system won't even let me re-install Win 7 or Reair the system. Each option gets to a screen and just hangs there. I've let it run for several hours on the screen that says ''Setup is starting'' but nothing happens.
  • 581 Answers
It more than likely has little to do with the operating system. It sounds like a hard drive problem. Are you able to format the harddrive and reinstall?
Posted on Jan 30, 2010
The Black Screen of ***** some are calling it.
Hi James Call for expert help for this issue +1(518)348-9393
Aug 20, 2016 | Microsoft Windows Vista Home Basic Edition...
PRODUCT ID 00426-OEM-8992662-00400 NEEDED KEY
Windows 7 and 8 will operate even without the code enteredt. It just keep stelling you to validate it anyhow. The problem started when a group didn't want to certify it's many computers were valid Windows versions of Windows 7 Professional, and made a workaround that skipped the key entry. Windows didn't like that and made a security update that kept warning users their software might be invalid. The problem is, even certified Genuine copies of Windows, will not now recognize ANY of the DVD key codes they came with originally. I know because it's done the same thing to me. Seems it will work fine with the numbers if you never update the security fixes. There are several ways to find the key codes that were entered to install the copy that your machine is running. Otherwise, never leave your machine online when you load Windows and all the key code information is fine at install.. Then bring it online after it is completely installed and you have inactivated to auto-update feature.
Nov 16, 2013 | Computers & Internet
My windows 7 all ready expire how can update my pc
Microsoft Windows requires an activate code when you install the operating system. This product key is evaluated each time the system is booted or when you decide to update the operating system critical files. If you installed an incorrect key or your machine's hardware changed significantly, the operating system prompts you for a valid key. If your product key has expired, you can contact Microsoft to purchase a new one. Enter a new key in the system settings in Windows to enable the operating system and continue using the machine.
Click the Windows Start button, then select "Computer." This opens your computer properties window. Click the toolbar item labeled "System properties." In the Window that opens, click "Click here to activate Windows now" and click the "Continue" button. This opens a dialog window with a product key text box. Enter your valid Windows product key and press the "Ok" button. Reboot the machine for the changes to take effect. The next time you boot, the operating system is activated and the error message no longer displays. Hope this helps.
Jan 01, 2013 | Microsoft Windows 7 Ultimate for PC
Toshiba Satelite A150-S4184,Hasent been used much,It was verry fast, now have internet again and loads very slow and takes long time to load pages,I think auto downloads instales windows 7,What can I
How much memory do you have in your Toshiba Satelite laptop?
Windows XP with Service Pack 3 needs a minimum of 1GB but ideally would run better with 2GB.
Windows 7 would need the same but there is no auto-update process to go from XP to 7 as this is not allowed - you would have to do a Custom install of Windows 7 which requires a clean install (i.e. format the hard drive and start from scratch).
If you are running XP with less than 1GB memory, then you need to check what the maximum memory that the laptop can be upgraded to?
The easiest method is to use the Crucial Memory web site System Scanner utility which will detect how much memory is installed and advise how much you can upgrade to according to the options available for the specific make & model of laptop.
If the laptop hasn't been turned on or on-line for a long time then you may be using a lot of resources downloading Microsoft critical updates plus updates for other installed programs like iTunes, QuickTime, Java etc.
Try downloading and installing a copy of the free Advanced System Care 5 utility then running the Deep Care tools which include System Optimisation and clean-up utilities to improve system performance.
Jan 02, 2012 | Toshiba Satellite A105 Notebook
Windows 7 home basic product key for Product id 00346-OEM-8992752-50258
Windows 7 Home Basic with the key you provided is an Original Equipment Manufacturer (OEM) version of Windows 7. These versions are auto-keyed/auto-activated with a BIOS check when booting to the media to install Windows.
The only times it should prompt for a product key are:
  1. Installing the OS on a different brand system other than the OED brand it was designed to be installed on.
  2. Installing Windows from inside an already running install of Windows instead of booting to the Windows media.
If this is the OEM system the OS shipped on and you are prompted for activation, flash the bios to the most current version and run the Microsoft WGA tools to clear the activation prompt.
If this is not the OEM system the media shipped with, then you can't activate it.
If you installed Windows without booting to the Media, then boot to the media and re-install Windows.
If under warranty, contact the OEM warranty service as they provide support for OEM Windows.
Jul 20, 2011 | Microsoft Windows Vista Home Basic for PC
My Gateway zx4800 booted this morning to a black screen with one window stating, "Personalizing Windows Media Player". It stayed that way for an hour. Ctl Alt Del finally let me select Task...
Good Day,
As I see it, the OS which is Windows 7 has automatic updates turned on, thus Windows Media Player has also been updated. If you have quitted or stopped the installation or "personalizing Windows" it may have this effect of slowing your system down.
To fix this you may restore the system at least a day before it bogged down.(boot into safe mode first) after which see the results, and let it re-update, and let it finish shall it show that screen again. Depending on your system configuration, Windows Media Player setup may take a while.Just be patient.
Hope this helps. Thank you for using Fixya.
Jul 10, 2011 | Computers & Internet
Fujitsu N6420 upgraded to Windows 7 Professional. Ran fine for a month or so until it hung in middle of automatic Windows update. Now can not boot from hard drive or CD--gets to Windows logo splash screen...
If you still have the install disk you can put that in, hold F12 as the computer is booting up, and choose to boot from CD. The setup disk has a repair option that might fix the problem.
Apr 06, 2011 | Fujitsu LifeBook N6420 Notebook
Failure configuring windows updates Reverting changes do not turn off your computer....I am stuck here...What do i do? windows 7 ultimate 64
If the computer appears to be frozen in a program, the update will not do you any good.
Depending on how long you waited, I would invoke the task manager and see what process is hung up.
press ctrl/alt/del simultaneously only once, the task manager screen should appear, select the bottom option.
When the window pops up, select the far left tab (applications or programs) and see which is running or which is not.
If there is one or more that are not responding, terminate them by selecting them and clicking on the button end program.
You will get a warning, acknowledge it and continue.
If this was holding up your system, you should be able to restore your system to an earlier point using system restore.
If your system is COMPLETELY unresponsive, then you have no choice but to shut it down. hold the power button for 5 sec (default power down)
when the system comes back up, it will ask you how you would like to boot, (safe mode normal mode.....)
Select normal boot up.
Restore your system to the last restore point.
When your system is again functioning properly, create your new restore point, then try the update again.
Good luck
Sep 28, 2010 | Microsoft Windows Vista Ultimate Edition
Vista hangs on restart at end of sp2 upgrade
Take advantage of Microsofts offer to go to Windows 7. You will solve this one problem now only to encounter more later.
Jan 09, 2010 | Lenovo ThinkPad T500
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
