I know some methods to reset bios password. 1. The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box, take out the cmos battery from the mainboard. Then the bios password will be reset to blank. Put it back after a few minutes. 2. Follow some tutorials. For example the tutorials: Reset HP / Dell BIOS Password.
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
If you don't know the BIOS password, and need to access it - you'll have to
unplug the AC power then open the case and remove the lithium "coin" or "button" battery from the
motherboard. Wait 5 - 10 minutes (allows the capacitors to discharge) and replace the battery. This will RESET all BIOS values to default.
Restore AC power reboot. Enter the BIOS and change the values as desired. To access the BIOS, Press the F2 function key repeatedly during boot sequence. You may need to plug the USB keyboard into a different USB port if it doesn't let you in to the BIOS page.
I hope this helps & good luck! Please rate my reply - thank you.
I know some methods to reset bios password. 1. The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box, take out the cmos battery from the mainboard. Then the bios password will be reset to blank. Put it back after a few minutes. 2. Follow some tutorials. For example the tutorials: Reset ACER Aspire 3610 BIOS Password - Only 8 Steps
The easiest method is to go through the door bellow. You can attempt to reach the latch by removing the top panel of the washer and working from the top, but it can be difficult to reach for some people. If you have quesitons, please post back and let me know. I hope this helps you.
Drain pump screen is clogged. If its makeing a bad grinding sound the pump will need to be replaced. Otherwise disasembly of the machine is required to access pump area to clean out screen. Dextrous people can probaly do this from the back or underneath unit. Its difficult and I don't recomend it to beginers or people who arn't handy. Easiest/prefered method: (This is the one I use.)
Method A units that have a bottom access panel. ie: front panel not one seamless peice.
-unplug unit
-lean back against wall for easy access.
-remove two #2 square screws form access panel.
-Loosen clamp holding hose to tub. (Big black one around 2" in diameter.)
-remove and clean screen.
-reassemble machine and test pump operation.
Method B units the have seamless front panel.
-unplug unit
-remove top. 3 screws @ back, slide top away from machine to remove.
-remove 2 screws holding console onto chasis.
-remove disp
-remove 3 screws @ and behind disp area.
-Remove console. ( tab may be holding to front panel @ middle bottom use putty knife to pry up.)
-remove 4 screws holding front pannel @ top to chasis.
-remove 2 screws holding frong pannel to chasis inside machine. Acess from top. (some models only.)
-remove bottom screws either 4 or 2 usally 4.
-remove two screws holding door lock to front panel
-remove spring from around bellow.
-remove bellow from front pannel
-remove front pannel. Tilts forward and lifts up off supports. (some models only.) or pannel ifs up and off from white tabs in side of chasis.
-unhook wires to door lock from front pannel. (plastic molex tab)
-may now access pump like in method A.
Pump Replacement
-access pump area
-remove drain hose to pump by looseing clamp and pulling off.
-remove hose to tub by losseing clamp and pulling off.
-remove power connection at back left of pump.
-unscrew two philips screws holding pump too base plate. (only one is really required.)
-replace pump
-clean pump screen or add one if not present.
-reconnect hoses.
-replug in power
-reassemble machine
-test pump operation
Sounds to me like there is something stuck in back of the drive that is preventing it from staying closed properly. To fix that type of problem you would have to take the drive apart. There is 4 screws on the bottom of the drive, unscrew those screws. Unclip the front cover of the drive which the clips are located on the sides of the drive, the door will come off then you can take the top off.
From there you look to see if there is any debris and remove it, then put everything back together and hook the drive back up to the computer and test it to see if the drive will open and close when you want it to and not by itself.
It could also be just a bad drive, easiest thing would be to replace it but if your handy enough you can try the method I explained.
This machine has no belt. It does have a motor coupling. Easiest way to replace it is to lay the machine on its back. Remove the pump cilps and slide the pump out of the way. Remove the motor clips (they may each have a 5/16 screw), and slidt the motor out. Replace the coupling and assemble in reverse order. Coupling # 285753 available at www.timerking.com for 9.99 or from sears. Hope this helps!
Anthony, you usually need to pull the 3-sided cabinet off the machine to get that part installed. Some can do it from the top, but having the cabinet off is the easiest. You have to open the control panel up first, then unhook the lid switch connector harness, then pop out the two straps that secure the cabinet to the back/bulkhead. Now the while cabinet/top of the washer lifts away by tipping it up and forward towards you. Now you will see that lid switch bracket assembly you want to replace is easy to get at.
