Question about Refrigerators
Compressor runs only a few seconds then clicks off
Frigidaire FRS26LF7DS refrigerator - compressor runs only a few seconds then clicks off - repeats this cycle every 1 minute or so.
  • 65 Answers
The compressor is going bad, check your owners manual for warranty information or look here http://b2b.frigidaire.com/support/manuals.asp if you cant find the manual. Some units have up to 7 years on the sealed system (the compressor, cooling coils, and hot coils).
Posted on Jan 30, 2010
It keeps going through a start up process (clicking and the fan come on then off quickly) at first staying steady then getting longer in the start up process.
Hi David, thank you for your inquiry. I understand that your Frigidaire Refrigerator is cycling on and off more than you expected. Todays newer refrigerator's have to meet Dept of Energy (DOE) specifications for energy savings. Typically the fan and compressor runs to get the fresh food temp down to 34*, the compressor shuts off and the fan runs for thirty more minutes and shuts down. The fan will repeatedly cycle on and off to keep the temp down as close to 34*. Once the temp in the fresh food hits 40* for more than two minutes the compressor cycles back on again. This will cause the temps in the fresh food to dwell between 35-40 and in the freezer section between 8-15. Hope this helps! -JK
Oct 28, 2015 | Frigidaire Refrigerators
My frigidaire is not cooling. my fans run and my compressor tries to start every couple of minutes and runs for 5 to 10 seconds. keeps repeating this
That could be an overload unit is fault due to fatigue or the relay that need to change from start winding to run winding is fault.if not the compressor is short cycling due to less refegrant gas in the systerm.Find a leak and regas after sealing it
Aug 19, 2013 | Frigidaire Professional Series PHS68EJSB...
Frigidaire refrigerator noisy on off cycles every few minutes. freezer not very cold, then later fridge not cold either. unit made in 2002. could this be a bad compressor?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 06, 2010 | Frigidaire FRT18B4A Top Freezer...
Maytag MSD2351HEB sidebyside occasionaly goe thru frequent cycling buzz. Last for a couple of seconds, then repeats a few minutes later. sounds like a solenoid click when going off.
if this model has the techumse compressor it is probably drawing high amperage and kicking out. the click and buzz is the compressor winding stressing to draw the energy needed. compressor maybe bad. the compressor model usually starts with a t11...
Aug 01, 2010 | Maytag MSD2351HEB 33" 23 Cu. Ft....
Refrigerator installed under counter and stopped cooling
possible bad compressor. check amp draw of compressor. tech info is usally on model # tag on amps. If amps close to recommendation you could need a start kit but more than likly a compressor .
Mar 05, 2010 | Refrigerators
check the overload, take it loose and inspect it for a burnt spot shake it if it rattles replace the relay
you either have a relay bad or a stuck compressor
the compressor has a 5 year warranty on the part, the relay 1
so if you relpace the relay and it still doesnt run the compressor, call for serviece under warranty
Apr 27, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
321 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
