Question about Coffee Makers & Espresso Machines
Have just dual fuel fracino, but the cups are
Have just bought dual fuel fracino, but the cups are really stiff to turn, does it need cleaning or is there anything to help loosen them up and make it a easy smooth action? because it is making it really hard work
Emailed fracino direct, explained the problem and they told me exactly what it was and how to sort it ,, so happy now
Posted on Jan 31, 2010
How do i adjust the monoshock
there should be a c spanner in the tool kit. place it on the shoulder of the unit, match up the groves with the spanner and turn. might be stiff so use wd40. have a cup of tea and then start. make sure the shock s clean. watch your fngers.
May 26, 2014 | Yamaha Royal Star XVZ 1300 A Motorcycles
Flashing ready and water
Hi u machine looks like a fracino cherub if thats the case it sounds like the inlet solinoid open it up take it out its a littel blue box siral strip it make sure theres nothing blockin
g it test power to switch if all ok its the inlet solinoid switch 28.50 + vat. 6.50 POST from fracino hope I helped?
Feb 11, 2013 | Coffee Makers & Espresso Machines
Fracino little gem coffe machine manual
visacrem intternational limited
FRACINO COFFEE MACHINES
THE LITTLE GEM
INSTALLATION INSTRUCTIONS
.REMOVE PLASTIC BUNG & FILL TOP TANK WITH COLD WATER TO TOP (N.B WATER SHOULD BE SOFTENED)
.PLUG MACHINE IN & SWITCH ON AT MAINS
.TURN MACHINE ON (ON/OFF SWITCH ON SILER PANEL JUST UNDER FRONT RED PANEL- NEXT TO GROUP)
.RED NEON AND AMBER NEON LIGHTS WILL ILLUMINATE AND THE MACHINE WILL START TO FILL
.OPEN STEAM VALVE (TURN RIGHT HAND BLACK HANDLE ANTI CLOCKWISE)
.WHEN WATER LEVEL REACHES THE YELLOW LINE ON THE SIGHT GLASS THE LIGHT WILL GO OFF AND
THE MACHINE WILL CUT OUT
REFIL THE TANK AND THEN TURN THE ON/OFF SWITCH OFF AND WAIT 5 SECONDS TURN THE ON/OFF
SWITCH BACK ON THE MACHINE WILL CONTINUE TO FILL
.WHEN THE WATER LEVEL REACHES THE TOP RED LINE ON THE SIGHT GLASS THE RED LIGHT WILL
GO OUT THE AMBER LIGHT WILL REMAIN ON UNTIL THE WATER REACHES THE CORRECT LEVEL AND THEN
GO OUT
.THE MACHINE WILL NOW START TO HEAT THE WATER WAIT FOR STEAM TO COME OUT OF THE STEAM TUBE
(BETWEEN 5-10 MINS APPROX) AND CLOSE THE STEAM VALVE (TURN RIGHT HAND BLACK HANDLE CLOKWISE)
.WAIT FOR THE PRESSURE TO COME UP TO 1-2KG/CM3 (PRESSURE GAUGE ON FRONT OF MACHINE BETWEEN
THE TWO BLACK HANDLES)
.THE MACHINE IS NOE READY TO USE
.PUT EMPTY FILTER HOLDER INTO THE GROUP AND FLUSH WITH WATER BY TURNING ON RED SWITCH NEXT
TO PRESSURE GAUGE AND LETTING WATER RUN THROUGH THIS PROCESS WILL TAKE SOME TIME AND USE
APPROXIMATELY HALF PINT OF WATER THE GROUP AND FILTER HOLDER SHOULD BE HOT - CHECK BY
TOUCH IF THEY ARE NOT HOT LET WATER CONTINUE TO FLUSH THROUGH UNTIL THEY ARE AND THEN
TURN RED SWITCH OFF
.MAKE A TEST CUP OF COFFEE THIS FIRST CUP WILL PROBABLY BE COLD BUT AS YOU MAKE MORE CUPS
OF COFFEE THEY WILL GET HOTTER IF POSSIBLE LEAVE THE MACHINE TO STAND FOR APPROX 30 MINS
BEFORE MAKING COFFEE THIS WILL ENABLE IT TO WARM UP AND PRODUCE COFFEE AT THE CORRECT
TEMPRATURE.
HOPE THIS IS WHAT YOU WERE LOOKING FOR ITS WHAT THEY GAVE ME WHEN I GO MINE FROM THEM.
IF NOT HERES A LINK TO THE PARTS MANUAL AND CATALOG
http://www.fracino.com/technical/parts.html
http://www.fracino.com/machines/hand-fill-coffee-machines/little-gem.html
http://www.vendingexpress.co.uk/uploads/pdf/product-fracino-little-gem-automatic_4e7a1df44be5d.pdf
Jan 20, 2012 | Coffee Makers & Espresso Machines
How do you protect the seal when using the self cleaning process
When the door locks in self clean mode the gasket is compressed to keep too much heat from escaping. Over time they can get stiff and not compress as well.
If you spill something on the gasket try to clean it off before cleaning the oven as this will cause discoloration or stiffness. Otherwise, there really is nothing to do to protect the gasket. If it is compressed and stiff it should be replaced. Hope this helps.
Jan 04, 2011 | Maytag Ovens
My coleman dual fuel lantern wont let me pressure the fuel up with the plunger
Remove the plunger and oil the leather diaphram with light oil similar to 3 in 1 oil, and expand the diaphram until it is no longer stiff and contracted. If you do not know how to remove the plunger let me know.
Sep 16, 2010 | Coleman Cable Coleman Twomantle Dual Fuel...
8.50 Torque Rating Dual Rotating Tine Tiller: left old gas in tank and need to clean and start...
First step remove old fuel
Should be a turn off valve on bottom of fuel tank. Then go to the Carburetor were the fuel line runs to. on bottom is the float bowel. Remove the bolt in center of this bowel. drain old fuel out. Then turn on your fuel with bowel off. flushing the line. If not fuel runs out. Lightly tap the float. If still no fuel. Turn off fuel. Remove the float under the float is the needle and seat. Remove the needle if did not fall out. Clean or replace the needle. Then replace float and bowel. Turn fuel on check for leaks. remove spark plug check for spark. Should have a nice bright blue spark when you crank it. If so put a little fuel in spark plug hole. Give a pull. Or if you want dip the plug just to the end of threads in fuel. Replace plug . Should start right up.
May 18, 2010 | Craftsman 8.50 Torque Rating Dual...
Stiff clothes in my GE front load washer
Add two cups of white vinegar to the tub and run the hottest and longest cycle. this will clean out your machine thoroughly.
After that add one cup of white vinegar to the wash to prevent stiffness
Aug 05, 2009 | GE WSXH208A Front Load Washer
Burner not working properly
the injector nipple is blocked unscrew nipple antie clockwise and put in a cup of boiling water and sterident tablet then reasemble.
Mar 12, 2009 | Rangemaster Classic 110 (Dual Fuel) Dual...
Coffee Makers & Espresso Machines Logo
137 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
