Question about 11Wave 11wp-611a Wireless Adapter
1990 over heating mustang
Over heating 1990 mustang.already replaced the radiator and fuel filter,sparkplugs,thermastat.give up.
  • telzinga Feb 18, 2008
    i have a seperate electric fan that is not hooked up to my electrical system. i stil have an over heating problem.running out of ideas.my buddy thinks its the coolant. i am currently using 50/50.wich should be right.no water added.all pre mixed.
  • Anonymous Jul 15, 2008
    1990 Ford Mustang GT
    Running very hot - on the N after short driving distance - replaced water pump, thermostat, radiator, and new after market fan (not quite as curved as orginal) Please help have no idea what it is- I was told by a mechanic that there may be something wrong with the fan clutch, but that shouldnt cause the overheating.) Please help!
    If something is wrong with the heater cord would it effect the cooling system?
Im losing my fluid,i replaced radiator,thermastat, and car is still running hot.also took it to the dealer they said it could be the head gaskit.i didnt replace the fuses i was mistaken.is there anything else it could be??? thanks for your help/
Posted on Feb 28, 2008
  • 2,039 Answers
The electric fan dont start check fuses if i remenber the relay is under the front seat lock under the seat you probably have corosion on wire
THANKS FOR USING FIXYA
PIERRE
Posted on Feb 18, 2008
  • pierre laplante Feb 18, 2008
    that fan is suppose to start when the car is hot if the fan dont start that our problem engine off try to turn the fan with our hand it have to turn freely let me know
    pierre
1990 Mustang gt cranks but will not stay runing
If the fuel filter is clean, you may want to ditch that EFI for a 550 or 600 CFM spread bore Vac. secondary carb. Or you could repair/replace the EFI...
Sep 21, 2014 | 1990 Ford Mustang
1990 mustang gt will not stay runing have to give
check the fuel pressure with a gage and check the fuel volume as if either one is bad can cause this problem.
Motor shakes very bad
camshaft bearing maybe
Dec 22, 2017 | 2000 Ford Mustang
1992 subaru legacy 2.2 liter overheating and no heat. already replaced waterpump,thermastat, radiator and hoses
You mean the car is running fine but just No Heat?
If so
-Sound like the heater hoses are plug. or the control valve is no function
-Check the heater control valve and flush the heater unit with water of garden hose from both directions.
Q: How do I know that is working or not?
A: Slide the heater control from Hot to cold or cold to hot and check it turn or not. (If not turn at all. The cable is broken or slip off)
Mai Lor
Feb 22, 2013 | Cars & Trucks
I have a 2000 ford mustang and the heat is not working. cold air comes out when i turn the heat on.
check to make sure the heater control valve is opening/ check to make sure that you have pressure in the radiator (about 14-19 lbs) be careful not to get burned put a towel over the cap before opening.!
if you pressure! check to make sure that the thermastat is good if thats ok ..check to see if you have water going through the heater core if you do check to see if the door is opening inside. between the heater & the air conditioning if you have air
sometimes critters get into the heater box to keep warm if all else failes change the radiator
Feb 25, 2010 | 2000 Ford Mustang
The heater takes longer to heat up then it used to, and when it does it des not stay heat. It blows out cool air? We have gone through the fuel system and cooling system without success. Antifreeze in...
the fuel system is seperate from heating system.check water pump the impeller could have deteriated i have seen this in another cavalier,once i removed water pump the blades that move the water were full of holes.but first make sure ther is good flow to the heater core.also hope you used a 50/50 mix of antifreeze because solid antifreeze wont heat up.
Jan 10, 2010 | 1992 Chevrolet Cavalier
Got a Toyota Hilux 93 over heating
it could be the thermastat,radiator
Apr 10, 2009 | 1990 Toyota 4Runner
I have a 1990 ford f150 v8 302 no heat
I would have to assume that the water has heated up,, but there is also a valve in the heater hose, at the firewall that opens when you turn the temp knob. if the hose going to the firewall is hot, and you are not getting heat inside, the valve is not opening. It can be mechanical or electrical. Not sure about yours.
Feb 19, 2009 | 1990 Ford F150
11Wave 11wp-611a Wireless Adapter Logo
89 people viewed this question
Top 11Wave Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a 11Wave Computer and Internet Expert? Answer questions, earn points and help others
