Question about HP Color LaserJet 2600n Printer
Printer streaks on card stock
My HP Laserjet 2600 prints fine on paper but when I try to print on card stock I get black streaks
    Scholar:
  • 94 Answers
Adjust your thickness guage as card stock is 3 or 4 times thicker than a 20lb plain paper stock. Here is link to a helpful media guide for HP printers.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/bpl05339/bpl05339.pdf
Posted on Jan 30, 2010
Testimonial: "Thanks. It looks good but I'll need to study it."
  • Lou H
    Lou H Feb 02, 2010
    NP I've been supporting Digital Printing companies for 20 years - and in my home I found using the manufactures paper stock and toners make the difference as well.
    how do you like that printer (asside from recent issue) I need a new color printer for the house and I'm sure my wife will want to also print pictures of the baby.
Paper jamming only takes card stock however does not print anythi
I would replace the printer if it was giving me that much trouble.
May 11, 2017 | HP LaserJet IIIp Printer
Will this printer print on heavy card stock and
Yes the 2600 will print on heavy card stock and vellum paper. I had one and did some landscape proposals on this printer and also printed on card stock as well.
Oct 17, 2009 | HP Color LaserJet 2600n Printer
HP LJ 2600 "dirty" printing
If the toner cartridges are "refills" that might explain some of your print quality issues. Unfortunately, HP only has 2 replacement parts for that model, the fuser and the ETB (Transfer belt) both would require a technician to replace. Check the transfer belt of any tears or punctures. Careful not to touch it, oils from your skin can cause quality issues as well. If at all possible replace all the toners with ones that were working fine.
Jul 31, 2009 | HP Color LaserJet 2600n Printer
HP Printers: 2600 and 3100N are printing streaks of lines.
2 things;
1. Try cleaning the print head assembly - including the plastic band that runs from 1 side through print head to the other side.
2. Check the driver for printer, reinstall if above does not work.
Jul 09, 2009 | HP Color LaserJet 2600n Printer
LaserJet 1020 printing solid black pages
1.replace the cartridge.
2. check PCB board contacts
3. replace PCB board
Jun 19, 2009 | HP LaserJet 1020 Printer
STREAK LEFT ON RIGHTHAND SIDE OF PRINTED PAGE
Fuser sleeve is contaminated and needs replacing - cheaper to replace the printer.
Apr 16, 2009 | HP LaserJet 1020 Printer
HP laserjet 5000N - Paper jam under the cartridge every time try to print
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | HP LaserJet 5000n Printer
Blinking yellow light
I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
Nov 30, 2008 | HP Color LaserJet 2550n printer + HP Color...
HP 2600 ghosting
It is a massive pain but a solution that worked for me is to run a 'clean' after every card stock sheet. I know it's wicked awful but it actually worked and I had to run 100 times (one for each good color card stock)
First put plain paper in tray 2
Next
Hit left arrow until you get to 'system service' and press green check
Next
then go to 'clean' and press check
Now it should print a clean image without ghosting
May 29, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
741 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
