Question about Canon PowerShot S60 Digital Camera
Horizontal bar in the image - Canon PowerShot S60 Digital Camera
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Posted on Jan 30, 2010
Brother HL-1250 owner's manual
Three Horizontal lines indicates a 'Light Burnt Drum'. The drum units are light sensitive. If they are left in the light too long they will be affected and it will show as black horizontal bars. The number of bars really depends on the circumference of the drum some are 2 some are 3 some can be 5 etc.
Solving this you can only replace the drum unit. Check with your local remanufacturing outlet to source a replacement drum unit at a price WAY better than buying new.
Apr 02, 2014 | Brother HL 1440 Laser Printer
Screen ghosting
Hi !
How old is your iMac ?
SOunds to me like it has been left on too long for too many years..
THese screen eventually burn in and then it's the end...
Sorry.
Mar 04, 2013 | Apple iMac 24" Desktop
At first it briefly had the vertical bars running across then stopped and now It smells and has an message ee
Hello
The horizontal output section of your standard tV should be troubleshooted. There is smot shorted component/s. You have to open your tV to check it. Check the horizontal output transistor, which dirves the LOT. If found shorted, replace it along with LOT.
Let me try to insert the images of these components here. The first two images, have wires are LOTs. You have to check which type is fitted to your set, and have to buy an exact type, both in number and size. The images horizontal output transisotrs is also attached here.
Feb 21, 2012 | Televison & Video
Blue vertical bar Left side and yellow,red vertical bars are seen both side of screen cause images are not readable
Hello
If the monitor displays these vertical bars, after a service has been done to it, and if LOT has replaced, there is a mismatching problem with replaced LOT and the defelction yoke.
Dec 18, 2011 | LG Studioworks 700S 17" CRT Monitor
When connected to any computer and attempt to play any video,it has a bunch of horizontal lines resembling a barcode running horizontally across image.
Hi my name is Vortash the bars you are seeing are the result of a capacitor or diode failure in the projector possibly in the power supply , they are usually referred to as ac hum bars .. this is where a circuit that should be running on pure dc voltage is being tainted by ac seepage from another part of the machine .. its also possible with the heat generated in these units it is just bad solder or dry joints ,,, best get an engineer to check it though as ot may damage the bulb and I would bet money on a repair being cheaper than a replacement bulb hoe this helps regards Vortash
May 12, 2009 | InFocus Office Equipment & Supplies
How to find degree of horizontal symmetry of Image?
If you use Adobe Photoshop, you can use ruler tool. Just drag from the start point to the end point of your horizontal (as example horizon line from a landscape image). It will display the Arbitrary degree in bar (just below the menu bar).
P.S.: If this information was helpful, please rate this solution. 1ak+f4pj7cbm32cuniyi2gaaaaaelftksuqmcc
Mar 19, 2009 | Apple Computers & Internet
White vertical lines in image w/ 2 inch black bar horizontal.
the black bar is from the light tunnel collapsing. the white lines are from the colorwheel or the main board has a cold solder joint. replace the tunnel and colorwheel and have the main board looked at.
Nov 12, 2007 | InFocus ScreenPlay 7205 Multimedia...
Canon PowerShot S60 Digital Camera Logo
310 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
