Question about Delta 36-716B 10" 1-3/4 HP 120/240V Induction Left Tilt Hybrid Saw w/ 30" Unifence
The motor on my delta 10" table saw starts a low rpm and does not go into high rpm - after a a few seconds it fails the circuit breaker, and without the belt conected this does not happen. Is the motor fryed?
This saw tends to have a problem where the belt rides "outside" the V-grove. Check that the belt is actually installed into the V-grove, and that the grove is in line. Mine was installed (at the factory) with the shiv back to front, so the belt would catch, and kick out. Maybe the same issue.
Posted on Mar 03, 2010
MY ROCKWELL 10 INCH TABLESAW SUDDENLY QUIT WORKING. IT TRIES TO COME ON WHEN I HIT THE START BUTTON, BUT BLADE TURNS 1/4 INCH THEN STOPS. CONTACTOR STILL HUMS THEN THE BREAKER TRIPS. PLEASE HELP!!
If the blade turns freely by hand,check the motor brushes.Most high quality power tools have easily replacable brushes,and they usually only cost a few bucks.
Sep 15, 2012 | Delta Saws
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
I HAVE A CRAFTSMAN MODEL # 137.218041,, 10" TABLE SAW. WAS RUNNING FINE, BUT WHILE CUTTING 2X4'S FOR FURRING THE SAW MOTOR STARTED SMOKING AND THEN QUIT. IT ALSO TRIPPED THE CIRCUIT BREAKER. I RESET THE...
Sounds like you may have overheated the motor. I'm surprised the overload on the motor didn't trip first. With this overheating, the windings in the motor have basically shorted out to ground. This is why your breaker is tripping. Rewinding the motor is no longer the option these days. You can try going online to www.searspartsdirect.com
May 15, 2010 | Craftsman 10" Table Saw
Delta Side Kick table saw will not start,
If there is no response at all, check the circuit breaker on the motor. There is a heat triggered breaker there. That is the most common cause of this. If that is not the case, please update this and we'll look further.
Dan
Feb 01, 2010 | Delta Saws
Motor has started t0 smoke and trips circuit breaker
On the motors I deal with there is a series of numbers that identify the shaft size, hp and all other requirements. I would try and contact a local Grainger and see if they can help, if not try in the yellow pages for a motor repair shop in your area and sometimes they can get you one. Good luck
Jul 18, 2009 | Craftsman 10" Table Saw
My table saw stops after a minute or two i replaces the capacitor and still does the same the breaker pops out
This means it's drawing high amp. Could be just packed with saw dust, getting hot. The breaker is probably thermal. Clean it up good. If it still trips, check for name plate current on motor and test.
Jun 22, 2009 | Delta 36-716B 10" 1-3/4 HP 120/240V...
Makita 2704 I overloaded my motor
if the motor RPM drops dramatically when the noise starts, it is probably a dry motor bushing, if this just started, lubricating the motor may just fix it.
Feb 13, 2009 | Makita 2704 Contractors 15 Amp 10 Inch...
Delta Radial arm saw 33-990 tripping circuit breaker
More than likely motor but try this , if you have a wrap around amp probe or can borrow one or purchase a cheap one place the amp probe around the positive wire connected to panel breaker ,with meter on proper scale ,start saw and read probe current , if cap bad current will be high and stay until breaker trips , if motor will start high on start ,then low then ,very high and breaker will trip , be careful in panel working around live circuits , the reason it reads this way is because as the motor warms the laminates it the armature separate and cause the increase in current to spike ,if cap bad never gets to speed and has high current draw constantly , to verify cap(1) remove from circuit (2)place a screw driver across terminals to release any charge (3), then take ohm meter on ohms place meter leads on terminals one on each terminal at same time meter will rise and fall back(4) reverse leads and should rise and fall as before if it does this it is more than likely good a lot of electrical reasons for this but this will tell you what you wanted to know , good luck
Dec 08, 2008 | Saws
Delta 36-716B 10" 1-3/4 HP 120/240V Induction Left Tilt Hybrid Saw w/ 30" Unifence Logo
195 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
