Question about HP Pavilion F1703 17" LCD Monitor
Problem for HP Pavilion F1703 17" LCD Monitor Screen going to black no picture, displays a few seconds then disappears. I have this exact problem and it seems likely this is the problem.( Your solution about the power supply caps) How easy is this to do myself for a novice as taking it somewhere will likely cost almost what a new similar monitor would
  • 11,361 Answers
Picture appears for 2 seconds and goes black
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 19, 2014 | Elo TouchSystems Computers & Internet
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Display on hp pavilion a1600n disappears
nuked this comment
and the Fixya dates are wrong,
must be those Grimlins, do inside?
the year stamp is wrong.
Oct 26, 2017 | HP Pavilion a1600n (882780776265) PC...
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
HP F1703 Screen goes black within seconds of startup
That is either the backlight or its power supply.
This is a bit tricky as you can get it fixed under warrenty but they will likely ask you to send back the entire computer not just the monitor. It is also something that you could fix or several shops could but the repair cost really isn't much less than a new monitor. You are not stuck using an HP monitor so anything will work and you can get quite a lot bigger or better for about $120 and up. Repair cost is going to be $80-$100 so as you can see for just a few dollars more you have a new warrentied monitor.
Apr 27, 2010 | HP Pavilion F1703 17" LCD Monitor
Video problem. Pavilion ZE4805US laptop
Most likely it is either a bad lcd inverter, due to the fact that you have clear picture on an external monitor. The inverter reduces the voltage coming from the motherboard to a lower level in order to power the lcd and the backlight. If this goes bad then you either get a picture randomly, a dim picture, or no picture on the lcd.
Feb 05, 2010 | HP Pavilion Ze4805us Notebook
Screen going to black no picture, shows a few second and disappears
First thing to look for are bad caps in the power supply section, see example of failed monitors due to bad caps here: http://s807.photobucket.com/home/budm/allalbums
Jan 16, 2010 | HP Pavilion F1703 17" LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
Monitor keeps shutting off after a few seconds- hp dv4000notebook
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 09, 2009 | HP Pavilion dv4000 Notebook
Display problem
When the screen goes dark shine a flashlight in the lower right hand corner where the Start button typically is located. If you can see faint images then you have a backlight problem. If you don't see anything then try connecting a spare monitor in its place. If that works then you have some other type of problem involving your LCD monitor. In both cases unless you have the experience and tools to safely work on fairly delicate electronics this is not a repair job for the typical consumer.
Feb 09, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1703 17" LCD Monitor Logo
230 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
