Question about Husqvarna Viking 1
The bobbin thread is bird nesting on my viking emerald 183. i've only had one sewing class so far. how do I insert the bobbin correctly?
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Make sure the bobbin is extended out of the bobbin case via the tension spring mechanism in the bobbin case. This provides tension for the bobbin unit. Check to make sure the upper thread has not "jumped out" of the take-up lever so that when the needle first touches the fabric the thread is still taunt and when the needle enters the fabric a small loop is formed right above the fabric and the eye of the needle. If these tips do not help suggest that you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Posted on Feb 14, 2010
2 Suggested Answers
  • 371 Answers
SOURCE: the bobbin is bird nesting on my viking emerald
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever and the bobbin is guided through the tension spring in the bobbin case. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
When I sew I have thread bunching up underneath the fabric, I've changed needle size, thread, bobbins and cleaned out around the bobbin holder. I'm frustrated and out of ideas.
Susan--
Easy peasy, once you know the problem and how to fix it. It's called "bird nesting" or "thread nesting" or what I refer to as thread "barfs."
Install a brand new needle.
Remove all the thread from the machine.
**ALWAYS RAISE** the presser foot and rethread the top thread.
Verify the top thread path is correct.
Install and thread the bobbin case, make sure it is correct.
Set the top tension to the midway point.
Now retest your machine. Birds nests gone? You may need to tweak the top tension because the factory standard changes due to age and use.
FWIW, problems appearing under the fabric are an issue of the top thread. Thread problems appearing on top of the fabric is a bobbin issue.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Mar 25, 2017 | Sewing Machines
How can I repair the top thread from tangling in the bobbin stopper for the Husqvarna Viking Emerald 118?
Thread nesting in bottom usually means that top thread is either not threaded correctly or top tension dials has lint caught in it. Use canned air to blow it out. Also change needle.
Dec 10, 2014 | Husqvarna Sewing Machines
Why does thread gather in bobbin area and jam machine
Completely unthread the top and bobbin threads. Clean any lint build up out of the bobbin race assembly using the little brush and some canned air. Check that the needle is inserted correctly...with the flat side towards the back. Then carefully rethread the top and the bobbin threads. Make sure the bobbin is inserted correctly...if it's backwards the machine won't sew properly.
Jun 30, 2014 | Brother PE770 Computerized Sewing Machine
Birds nests embroidering husqvarna viking designer se
it would be a good idea to have the machine serviced
Try these suggestions for bird nesting
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Feb 19, 2014 | Sewing Machines
Bobbin tension on a huquvarna
Birds nests on the bottom is NOT the bobbin tension. First make sure you are properly threading your Husky with the presser foot in the UP position. then to a test seam on a scrap of the same fabric. If it still nests.... tighten the top tension. and test again. Keep tightening the top tension and testing until you get it resolved.
Oct 12, 2012 | Husqvarna Viking 1
Bobbin case jumps out of place when free-motion quilting
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
bird nesting problems
1. Change needle
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Sep 12, 2012 | Sewing Machines
The bobbin is bird nesting on my viking emerald
Good luck.
Nov 15, 2009 | Husqvarna Viking 1
Sewing Machines Logo
538 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
