Question about Sony STR-DH500 A/V Receiver
I have a sony str-500 and when i plug it in all it says is protect.
    President:
  • Sony Master
  • 1,114 Answers
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jan 30, 2010
PROTECTOR/CHECK CODE 21 COMES ON ONCE A WEEK OR SO.
STR-DA2000ES, STR-DA3000ES and STR-DA5000ES:
Doument Reference: E23914196
Subject/Description: "Protect 21" is displayed when connecting to speaker/powered subwoofer combo
SYMPTOMS
Protect 21 is displayed when connecting to speaker/powered subwoofer combination model such as the SA-VA7000ED. The problem was also found to occur when connected to the Definitive Technology POWER MONITOR 500 and POWER MONITOR 700 series speakers.
CAUSE
The DC detection circuit is triggered when the speakers are connected.
RESOLUTION
Add a 4.7k metal oxide film resistor across capacitors C1319 and C1329 located on the D-AMP board.
Hope this helps. =)
Oct 23, 2009 | Sony STR-DA5000ES Receiver
Sony str-d715 flasses protector
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
May 03, 2009 | Sony STR-D700SS Shelf System
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
Sony STR-D460Z receiver
A common cause are failures in the amplifier output stage, the drivers, and some of the support components. You will have to send the unit out for service.
Jerry G.
Feb 08, 2009 | Sony Audio Players & Recorders
Help
check/replace your speaker wires. If a wire came loose, it will go into "protect" mode and shut down, to protect from a short circuit.
Jun 16, 2008 | Sony STR-DE525
Sony "Protection" mode - STR-DE725
My sony used to do that to umm cant remember the model but yeh i could play it at low volume but as soon as i turned it up it would start clicking and telling me to turn of the power...
I resolved it by checking every cord connected to it, it turned out that because I connected two speaker cables together i didnt seal it properly and they were touching this was making it go into protetion mode.
Nov 25, 2007 | Sony STR-DE725
SONY STR-DE675 RECEIVER
check the speaker's connections, I got them message when a speaker wire was unplugged and plugged back in while the unit was powered on
Oct 02, 2007 | Sony STR-DE675 Receiver
Sony STR-DH500 A/V Receiver Logo
595 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
