Question about Kwikset UltraMax Powerbolt 1000
The latch doesn't go all the way out when lock button is pressed.
I have a 1999 mustang, the driver side door was fine then all of a sudden would not stay shut. the door latch won't latch. could this be a electrical problem? it has electric locks
probably that the latch is in the first lock position preventing it from locking properly
use a round bladed screw driver , place it under the latch and press the door button and the same time pulling the latch out
Aug 12, 2016 | Cars & Trucks
Rear latch lock stuck in the open position
use a round bar ( a screw driver ) and place it under the latch and pull the latch out as you press the button to unlock as if you were opening the door.
Jan 06, 2014 | 2008 Chevrolet Uplander
Engine doesn't crank over, blown fuses and certain things not working?
sound like dead battery.no power to fuses if battery dead use digital voltmeter check battery volts should 12.6 volts if not have battery charged tested.if battery 4 or 5 years old battery could be faulty.
Apr 29, 2013 | 2010 Mitsubishi Lancer
Unlock scooter seat
Try some lock cleaner\ lubricant, use liberally, press down gently on the seat locking latch. If that doesn't work try shocking the mechanism with my favorite tool, a rubber mallet. If the key turns that part of the mechanism works. Put the key in to the release position. Go to where the latch is, use a bright light, see if the latch is engaged, Usually this kind of lock uses a hook latch. The hook is literally apart of the key barrel so if the barrel moves the latch hast to be moving too. Check the chair itself that its not stuck. WARNING Lubricate with pure silicon spray only it wont stain your chair. Lub all rotating joints and see if you can move it.
Hope this helps
Jun 21, 2012 | Health & Beauty
Drivers side door lock will not lock. Locks are power locks and button works.But door does not lock
the door lock actuator inside the door has gone bad.if the other doors lock and the driver's doesn't then the actuator has gotten too weak to move the lock/ latch.
Aug 13, 2011 | 1995 Ford Explorer
Washer will not start. Accidentally pressed 'off" button and now the start light is blinking and I can't change the settings or start the washer
try unplugging the washer for 5 mins. to reset the main control board, if that doesn't help check to see if both door latches are locking
Jun 03, 2011 | Maytag Neptune MAH5500B Front Load Washer
Can noy open my boot door
ford ford ford...
1 - press the bootlid down hard while you press the button 2 - put the key in the lock and try to use it to push the button further in... either theres something stuck in the latch, or the lock has moved a little and needs to be reset or the mechanics of the lock are worn out and you need a replacement, i remember these were a lock/latch combination and when they're done they're done - no fixes with zip ties / wire ect.
Jan 15, 2010 | 1994 Ford Probe
I have an old(over 20 nyears) free standing magic chef model No. 177-31DB2 range. I put it on the cleaning cycle and everything seemed to be working well. But then it seemed like there was alot of smoke so...
WHEN THE DOOR IS LOCKED ON A SELF-CLEANING RANGE, AND THE TEMP GETS ABOVE 400 DEGREES, IT LOCKS THE LATCHING ASSEMBLY SO YOU CAN'T OPEN THE DOOR AND GET SCORCHED. IF YOU FORCED THE HANDLE TO TRY TO OPEN IT, YOU BENT THE ARM OF THE LATCHING ASSEMBLY. IN ORDER TO RELEASE THE LATCH,
ONLY IF YOU FORCED IT TO THE OPEN POSITION, YOU MUST FORCE IT BACK TO THE LOCK POSITION TO STRAIGHTEN THE ARM.THEN IT MIGHT RELEASE.
IF YOUR RANGE HAS A LOCK BUTTON THAT NEEDS TO BE
PRESSED TO SLIDE THE LATCH TO THE LOCK POSITION,
YOU WILL HAVE TO SET ALL CONTROLS BACK INTO THE CLEAN POSITION AND PRESS THE LOCK BUTTON TO RELEASE THE LOCK ON THE LATCH ASSEMBLY. YOU SHOULD HEAR A BUZZING OR HUMMING SOUND WHEN THE BUTTON IS PRESSED.
Mar 31, 2008 | Kitchen Ranges
Door locked open
Tool: We cut a piece a wire about 10 inches long from a wire clothes hanger. On one end we bent 1/2 inch of the wire in a 90 degree angle with needle nose pliers. On the other end of wire we put another bend at least three inches.(this end will be your handle end) Process of using homemade tool to release latch: Make sure washing machine is on a wash cycle. Use flash light to locate latch in the locking catch. Insert the small bend of the tool into the locking catch. Then hook onto the latch and pull out --apply a small amount of pressure -- about three lbs of pressure) Then at the same time you are pulling, press in on the door release button (the little white button above the latch hole where you now have the wire inserted). As your are pulling with little pressure on the latch, hold the little white button in and press the start /stop button. You should hear the door lock. Let machine start working. (about ten seconds) Now push start/stop button again and you should hear door lock release. Your lock catch should give away. This worked for us.
Feb 11, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Kwikset UltraMax Powerbolt 1000 Logo
56 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
