Question about Bosch 24 in. SHX99A15UC Stainless Steel Dishwasher
Bosch SHX99A15UC Dishwasher Detergent/Rinse Agent Dispenser door won't swtay closed
    President:
  • 1,462 Answers
The issue may be due to the worn spring mechanism that may lock and unlock when you close and open the Detergent dispensor....
The detergent dispensor lock can be got from the following link which may cost you 4 dollar from the following link
http://www.repairclinic.com/SSPartDetail.aspx?PartID=935391&PPStack=1
I have uploadedmthe photo for your reference
the part number is 935391.
If you want the overview regarding fixing the spring,without damaging the latch, please refer the following link
http://www.repairclinic.com/SSPartDetail.aspx?PartID=908524&PPStack=1
Please leave me comment, if you need further assistance
Rnj VinodKumar
Detergent/Rinse Agent - 4b810f6.jpg
Posted on Jan 30, 2010
I have a Bosch SHE4AM15UC diswasher. The rinse agent comes out at the gasget. The rinse agent light does not come on anymore windicating it needs more agent.
I would have to say the sensor may be fouled up and need to be cleaned if you are concerned about the light. If the rinse agent is coming out of the gasket I would look for small cracks around the dispenser, then the door panel may need to be replaced.
Sep 06, 2012 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Detergent dispenser not closing
split the door inner from the outer - screws round the periphery. you will need a multimeter check if there is a supply to the detergent dispenser when there should not be ie during rinse and hold program or before starting the cycle. if there is a supply then the module is faulty. if not then fault probably lies with the dispenser itself. having split the door you can see how to remove. there are two methods of fixing. most common is six screws holding clamps. some are a push and click fit
Jun 03, 2007 | Bosch SHU5316UC Dishwasher
Light appears stating to refill rinse agent
There is a rinse aid dispenser on the door.
Buy some from your local supermarket, open the dispenser and fill it. Close the lid and the light should disappear.
Sep 30, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Put dish detergent in rinse agent dispenser by accident
Hello and welcome to Fixya.
Aside from physically removing the dispenser assembly ( which would be quite involved and include taking the door panel off ) you should be able to "nuetralize" the dish"soap" by adding as much "white vinegar" as possible into the same location as the soap...the jet dry reservoir.
In fact you may have to try this several times, but you could also try pouring straight water into the reservoir, but that will take some time since it is "soap" as opposed to detergent, hence needing a lot of water to de-lute it to much of a degree.
I'd go with the "white vinegar" and repeat that several times through a "rinse & hold" cycle. ( do not add any dishes or cutlery...run it empty )
You can also add a couple of tablespoons of "vegatable oil" directly into the bottom of the dishwasher and some of your regular "detergent" before starting the "rinse & hold" cycle. This will give the soap something to react with and the "detergent" will also help "neutralize" the soap,,,hopefully breaking it down as a result.
To answer the second part of your post...
The effect is going to be oversudsing in the rinse cycle since this is when the jet dry/rinse agent is dispensed in the cycle. So what I'm hoping to accomplish with these suggestion's is to minimize the oversudsing or prevent it all together until the reservoir is "purged" of soap.
Let me know how you make out. It usually works in the cases I've had...eventually. I've seen plenty as you are not the first nor will you be the last...we all screw up, that's life ;o)
Good luck.
macmarkus :)
Jun 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
I accidently put Jet Dry DISHWASHER CLEANER in my rinse agent dispenser and I need to know how to drain it out..help!
if you leave loading draw or lid open and do a hot wash with no detergent water will enter replacing the detergent you will have to do this several times till wash tub runs with clear water then refill with rinse agent.
Feb 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
DETERGENT IN THE AREA FOR RINSE AGENT
Fill dispenser with boiling hot water and run through rinse cylce only. The say to your husband "Really?"
Aug 25, 2009 | LG LDS4821ST Stainless Steel 24 in....
Soap dispenser cover won't close
It sounds like it may be stuck between cycle steps.(this sometimes happens if the washer is open during a cycle)Try and run it through one full wash cycle as it is.Then check to see if the soap door will close.If not,the lack may be broken
Jan 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Soap dispenser
There is a screw cap on the back wall of the dishwasher,unscrew the cap and place your rinse agent in there.I groove on the door is for your dishwasher powder
Apr 09, 2008 | Equator 20 in. CD 400 Compact Dishwasher
Dishwasher Drying Problem
rinse agent is essential and best to use seperate detergent and rinse aid and not the combined tablets. if you live in a hard water area, essential also to use salt. the dishwasher will dry quite well - it relies on the last rinse being hot and then the water just evaporates. most dishwashers work like that but some turn on the element for short periods during dry.
Mar 29, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Rinse agent dispenser
The only "fast" way is to remove the dispenser completely and rinse with warm water until clean! (by removing front panel and then disconnecting jumpers and clips...can be tricky to do alone, as you need 3 hands to pry clips from dispenser to remove from door!) Oshie.
Sep 28, 2006 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHX99A15UC Stainless Steel Dishwasher Logo
188 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
