Question about Sony UP DR100 Thermal Photo Printer
It keeps saying door open and I can't find which door is open
    Guru:
  • Sony Master
  • 829 Answers
Kindly check all the trays , it can happen if any paper has got stuck , kindly turn the printer upside down and shake lightly do this after removing the cartridge and power cable.
Good Luck.
Posted on Jan 30, 2010
Hoover hnf 9147z keep on saying doore open but door is close
The door switch is defective and stuck in the open position. Replace the door switch with a new one.
Sep 26, 2015 | Hoover Washing Machines
I HAVE A SAMSUNG PRINTER SCX-4623 THE MESSAGE KEEPS ON SAYING DOOR OPEN CLOSE DOOR , TRIED EVERYTHING BUT NOTHING WORKS
Dear
The front door right side there is a lever found when it is opened the lever should close the micro switch inside and the door is locked with another short lock (near the long lever). If door lock broken then the micro switch push the lever and door not closed.
the basic problem with the micro switch and related mechanical alignment.
Thanks.
Feb 26, 2015 | Samsung SCX 4623F - Multifunction fax /...
My washing machine wont start it keeps saying door open i opened and closed door several times it continues to say door open. I unplugged it to see if it would reset but it didnt.
The door switch is likely broken from slamming the door. Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | Frigidaire Affinity ATF7000E Front Load...
Alarm burning issues. Electrical or just a cheap alarm?
means you have a shorted wire, it keeps touching the body or a ground wire causing the door to say its open. you also more then likely have a bad door switch. check the simple things first
Jan 28, 2010 | Vehicle Parts & Accessories
Door keeps popping open
You don't say what kind of refrigerator you have, so this will be a generic answer. You need to replace the door closing cams, which are located at the bottom hinges.
The cams provide a sloping surface or v-shaped notch to lift the door slightly as you open it. The cam's sloping surface causes the door's own weight to hold it closed. If the cam has broken, it can fall out or turn with the door, allowing the door to come open.
The magnetic gasket is only supposed to ensure a good seal, not hold the door closed. You don't need to replace it.
Mar 15, 2009 | Refrigerators
''Back door open, please close back door'' - back door is closed
This Error Is Reoccurring On All These Units Open Close Back Door Then Unplug For 30 Seconds And Then Plug It Back In. Check For Error.
The Brother Website Says To Check The Paper But Almost All Of These People Have Checked For Paper Problems And For Jams With No Result.
Jan 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
Door error
Sounds like a hardware issue, and the switch for the door is not being opened when the door is. Here is a link to the manual, and the service for the camera info is there as well.
Go here to download the manual for future reference:
http://www.vivitar.com/ecms.aspx/e65dedb4-5c74-4e09-8110-95947ea5f876/SupportFiles/ViviCam3713.pdf
Sep 14, 2007 | Vivitar ViviCam 3710 Digital Camera
Disc eject
sounds like the latch mechinisem for the disc door have it repaired as soon as you can. hope this helps
Aug 14, 2007 | Panasonic VDR-D100 DVD Camcorder
Sony UP DR100 Thermal Photo Printer Logo
35 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
