Question about ASUS K8V Deluxe Motherboard
I INSTALLED THE COMPATABLE VIDEO CARD BUT STILL GET THE MESSAGE FASTTRACK CONTROLLER NOT INSTALLED,BIOS. I NEED TO KNOW WHAT EXACTLY DO I ENABLE OR DISABLE IN THE ADVANCE SCREEN,OR WHAT CHANGES DO I NEED TO MAKE IN THE SETUP MENU. SEEING IF THAT FIXES MY PROBLEM THANK YOU
    President:
  • 1,015 Answers
Try going into the BIOS and into the advanced settings menu. From there look for the onboard devices menu then the promise controller and then set it to disable. Then save settings and exit. try re-booting and let me know if that fixes your problem.
Posted on Jan 30, 2010
  • muebe Jan 30, 2010
    I see that you just posted another question. So disabling the promise controller has caused another error. When you installed the video card did you disconnect any hard drive cables? If you did you may have left one loose or installed it back on the wrong connector it might be what has cause the original Fastrack controller error message.
Computer: Sony Desktop Model: PCG-242M. Computer does not start, with the inclusion hear one long beep and two short beeps. What is the problem?
Based on what you have presented...
1 long 2 short - (Video Controller Failure or faulty add-on card
Do you have an installed video card? Does the unit have a built in Card? (In other words part of the mother board?)
If you have an installed card check that it is not loose... If it is still not functioning (and)
If your unit also has a built in video card that is disabled... go to the BIOS and enable it... see if your unit will boot up...
If the video card is not loose and you do not have a built in card... you may want to see if you know someone with an extra card to loan... or purchase a new one....
Mar 31, 2011 | Sony VAIO VGC-RB34G PC Desktop
FastTrack tx2300 bios will not boot
Try using a different card with the same kind of slots if it works then your storage controller card is bad.
Mar 14, 2011 | Promise FastTrak TX2300 SATA PCI Adapter,...
I have toshiba satellite L505-S5990 model.i have installed windows xp by changing the settings in Bios that is sata hard disk enabled as compatable mode from AHCI.if i change to AHCI i can't install...
If you would like to make use of the SATA controller's AHCI features, you should enable this BIOS feature. But please note that enabling this feature requires you to load the SATA controller driver during the Windows XP installation routine.
If you do not intend to use the AHCI features, it's recommended that you disable this BIOS feature. This allows you to use the native Windows XP driver. You won't need to load the SATA controller driver during the Windows XP installation routine.
Read more: http://www.techmetica.com/howto/sata-ahci-mode-bios-setting.-what-does-it-do/#ixzz0y5ObAtN8
Aug 30, 2010 | Toshiba Computers & Internet
Ibm xseries 235 eserver....all of a sudden stopped booting...it was set up through a kvm swtich, the kvm detects a signal and lights up the apprpriate port, yet nothing is displayed on the monitor....
Please expalin how you know "drives are good" (sic) As it would appear to me that this is indeed your problem? Unless as you say the video card has turned up it's toes. As you said the best way to check that is to enable the onboard Video and check, exactly what happens when you do that? Yes it will automatically use the video, it would install a generic video driver,and show video, are you sure the monitor is OK,have you swapped it out? Simply removing the Video card will automatically enable the onboard video, so you won't need to get inro BIOS. Check the RAM too, and remove any other cards in it.
Feb 23, 2010 | IBM eserver xSeries 235 8671
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Feb 04, 2010 | ASUS P5LD2-VM Motherboard
Boot from non Dell raid controller
Check the Boot Sequence again -- if there are any "SCSI" devices listed, enable them, and make your CD-ROM the "primary" boot-device (so that you can install Windows) and make this "SCSI" device the SECONDARY boot-device, and disable the internal hard-drive, so that it won't be used as a boot-device.
Dec 27, 2009 | Dell Computers & Internet
Onboard video died, how do i enable the agp card
if you can't see bios on start up, after pessing F8 on xp, try with F2 and F4 .. if nither of that work, try to unplug pover cable , reset bios by pulling out little battery on mother board, that how you will reset cmos, and out bios on default state. And maybe than it will enable you your agp port.. try and let me know..
Jun 28, 2009 | E-Machines T3085 PC Desktop
Bios Settings
I had similar problem few years ago.
On the hard drive manufacturer site you should find utility which will "cheat" your laptop bios and control the hard drive bypassing the bios.
Nov 07, 2008 | Compaq Armada M700 Notebook
Missing driver raid
I have the Soltek SL-865Pro-775 motherboard and the driver CD that came with it when I built my computer. If youneed any of the drivers, let me know. teledrew@yahoo.com
Jun 20, 2008 | Soltek SL-865Pro-77 (SL-865PRO-775)...
ASUS K8V Deluxe Motherboard Logo
26 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
