Question about Nikon D70 Digital Camera with 18-70mm Lens
Nikon D70 flah not working, used to
I have a D70 thant I uded for 2 years without any problem. Now the flash is not firing. If there is little light the Speeedlight raises automatically, but the flash is not firing.
I tried turned off the Automatic ISO, tried diffferent setting, eye reduction, etc,at not avail.
Should I change the light bulb?... can I?
Thnks
MArio
  • 2 more comments
  • Anonymous Mar 07, 2008
    SAME AS YOU
  • Anonymous Apr 28, 2008
    flash will not pop up
  • dax83 Aug 23, 2008
    I'm having exactly the same problem as you.
  • jeanniericke Nov 10, 2008
    I have the same problem that started a week ago. Mine is also 2 years old and has always worked fine. Have you found out anything new on how to fix this?? or how much it costs?
    Scholar:
  • 97 Answers
I had this problem a while back, but was fortunate to get it fixed under warantee as it was less than six months after Nikon repaired my D70 for the "blinking green light of death" fault.
I'm afraid this is a repair job for Nikon or an autorized workshop. It is most likley the flash tube. If you fancy taking your camera apart (I warn you it would be a fairly difficult job) then please be aware that you may get a significant electric shock from the flash capacitor, which will remain charged.
Posted on Sep 05, 2008
D70 problems
I don't think doing a factory reset will solve this problem. Try upgrading it once more.
Apr 06, 2014 | Cameras
Is this flash to use on a nikon D70 camera. It works on a F70 but on a d70 its not functioning
The Achiever Flash 630AF is for Film Cameras and will not work properly on the Digital D70 camera.
Nov 29, 2010 | Achiever 630AF for Nikon TTL Flash
Built in speedlight on nikon d70 has stopped working. The light pops up, but no flash
If flash pops up and doesn't fire, little white pin/lever inside flash has lodged up inside flash casing and needs to be eased from where it is stuck. Careful when opening the flash up to dislodge the white plastic pin/lever, there are tiny wires you REALLY don't want to damage....
See how, with pics here:
http://www.stephanmantler.com/blog/d70s-camera-repair/
Sep 12, 2009 | Nikon D70s Digital Camera
Camera will not power up changed battery just went dead Nikon D70
Fixing a Dead Nikon D70 - Green Blinking Light My first-generation Nikon D70, which I bought the day it was released to the market a few years back, died on me a few months ago. Without a card in it, it won't start, and when you insert a CF card in the slot, the green data-access indicator flashes on and off. If I hold down the Menu button, the menu flashes on and off along with the green LED.
d70_87x1.jpgAs it turns out, this is a known problem with the original Nikon D70 cameras, and Nikon USA has a service bulletin out on the camera body. They'll repair it free of charge.
So, if you have the same problem, visit this service bulletin page, http://nikonusa.com/Service-And-Support/Service-Advisories/D70-Service-Advisory.page click on the D70, and you can access a PDF file that you'll need to print, fill out and send to Nikon along with your camera body. Be sure to take your camera strap off and remove the battery, and don't send any lenses or other accessories.
Mine's on it's way to Nikon now - they say the turnaround is five days (plus shipping time).
May 28, 2009 | Nikon D70s Digital Camera
D70 internal flash not firing
Check if something is preventing the flash to pop up 'fully'. Check for some dust or other particles trapped between the flash and the body. Does the screen say 'Subject is too dark'? If so, the flash has not popped up fully.
Nov 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Flash
If you shoot in Auto mode, the camera will not allow you to turn off the flash when it senses that it is needed.
To use the camer without the flash, change the mode to Program ("P"). Once it's in P mode, the flash will not fire as long as it's in the down position. When you want to use the flash, press the speedlight release button (the one with the little lightning bolt near the mode select dial).
Sep 26, 2008 | Nikon D70 Body Only Digital Camera
SB800 Won't Remote
The channel on the flash for remote on the 4a withthe NIKON D70
If you are using the Nikon D200 then the channel is 1a ...
If you have any more questions contact
Berrie Smith Camera Repair
bbmw@bellsouth.net
Feb 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Sb 600 under exposure.
You probably haven't changed the camera and/or flash back to TTL mode from wireless mode.  Make sure they are both set to TTL, not commander mode and you should be fine.  Note that the LCD on the flash will indicate which mode it is with a little graphic.  On the D70 you had to switch between TTL and Commander mode to set it up to work using the built in flash as the commander, so you just have to switch back.
Jan 21, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon D70 - indoor flash problems
Unfortunately, you may have a faulty flash pcb (printed circuit board) The part is around 50$ plus installation 200+ total repair cost. A work around would be to use an external flash unit from the hot shoe
Dec 26, 2007 | Nikon D70s Digital Camera
Nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
Sep 21, 2007 | Nikon D70 Digital Camera
Nikon D70 Digital Camera with 18-70mm Lens Logo
320 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
